MarshallForum.com
Reply
Thread Tools Display Modes
Old 03-12-2011, 10:22 AM   #1
squireno7
Junior Member
JCM 800 50 watt 4212 combo
my name is Rich. Im new here. I have had this amp since 1986. split channel/reverb,effects loop. original celestion's. Drake trans. it has been sitting for the last 12 years and it time to refresh it or sell it. it has GE 6550's. if I sell it what is it worth? it is mint. the volume knob is a little dirty but getting better with use. if i keep it I want Groove tubes 6550R. do I need to rebias it with these? and where is the adjustment for bias? this isnt fixed bias amp is it? I have the bias tool but didnt see where to adjust. i will do pre amp tubes also. I love tubed Marshall's but i just use it in home and its louder then i need. I was thinking about the haze 15 or maybe the Mg15hfx. i really like tubes but havent got prices yet. any thoughts
how do i make pics larger please
squireno7 is offline   Reply With Quote
Old 03-14-2011, 10:53 AM   #2
squireno7
Junior Member
Re: JCM 800 50 watt 4212 combo
nobody?? anybody...
Old 03-14-2011, 11:22 AM   #3
JayCM800
Senior Member
JayCM800's Avatar
Nice amp!
Yeah man, re-tube and re-bias, take it to a trusted tech (yeah, i know, easier said than done )
I hope i find one like that when i'm "out for shopping"!
JayCM800 is offline   Reply With Quote
Old 03-14-2011, 12:10 PM   #4
Blisster
Senior Member
Blisster's Avatar
Tell you what man. I'll do you a solid and take it off oyur hands for a straight $150 shipped.
__________________
Marshalls: 1992 JCM 200 DSL 100, 2007 JCM 800 2203, 1998 Valvestate VS102r
Marshall Cabs: JCM800 1960b G12m-70s, JCM900 1960a G12T-75, 1960 BX Greenbacks
Other: MESA Engineering 1991 Dual Rectifier Solo "Pre 500", MESA Oversized Rectifier slant cab w/ V30s
Blisster is offline   Reply With Quote
Old 03-14-2011, 12:24 PM   #5
redscott131
Senior Member
redscott131's Avatar
(1) PRICE
If you decide to sell your amp you can easily get $1,200 to $1,400 out of it. If you are going to sell it, I would first start off with craigslist, and then if that fails try Ebay. However, the volume knob MUST BE FIXED before obtaining these prices. The prices I gave you are the prices of a MINT, COMPLETELY STOCK & UNMODIFIED CIRCUIT, and FULLY FUNCTIONING (W/O PROBLEMS) JCM800 2205 2x12 COMBO AMP (like the one you almost have). If I were you I would not sell that thing. The tone that that amp produces, destroys/is way better than the other amps you have listed.
(2) BIAS
UNLESS YOU KNOW WHAT YOU ARE DOING, DON'T BIAS IT.....b/c tube amps can kill you with the stored up electric current they contain. However, if you are going to go ahead and do it at your own risk towards yourself..........YOU SHOULD read the info found in these links first, before you do anything.....
http://www.tube-town.net/diy/bias-setup-e.pdf
Bias FAQ
Pictorial of Biasing a Marshall Jubilee. - Seymour Duncan User Group Forums
http://www.marshallforum.com/workben...-how-done.html
Pretty sure this will be your bias adjustment
(3) 6550 TUBEs
THE JCM800's sound killer with the 6550 power tubes. The Groove Tubes GT 6550R is just an overpriced/relabeld tube. Here are some good links to get a look at some 6550 tube prices.
6550 Tube Types
6550 / KT88 / KT90 Power Tubes
redscott131 is offline   Reply With Quote
Old 03-14-2011, 12:39 PM   #6
Georgiatec
V.I.P. Member
Georgiatec's Avatar
Keep it...I have the 100 watter 4211 and have just re-valved it with JJ`s throughout (apart from a tung sol ECC83 in position 5....if it were a car it would be a NASCAR...it's got absolutely massive tone.
Georgiatec is online now   Reply With Quote
Old 03-14-2011, 02:18 PM   #7
GIBSON67
Senior Member
GIBSON67's Avatar
Keep it. I have a pair of those G12T75's with the vents and they seem warmer and creamier than newer G12T75's. I would only sell to upgrade not to downgrade.
GIBSON67 is offline   Reply With Quote
Old 03-14-2011, 04:31 PM   #8
guitarman8
Senior Member
Nice amp I use the 1X12 version. Some members have the wrong impression about this design they think the 1 channel 800 is the way to go. I found you can get the same sound as the 1 channel by just using channel 1 for gain. Just blast up the channel 1 volume to 3/4s or more and use the master at low numbers. Great Page distortion but with this amp you have reverb and effects loop.
You can also use the switching thing if you want to for small clubs. Nice bright amp. If you're going to cash out I'd shoot for $1200.
guitarman8 is offline   Reply With Quote
Old 03-14-2011, 09:01 PM   #9
squireno7
Junior Member
Quote:
send me your address............you never know what will show up at your door
Old 03-29-2011, 12:52 PM   #10
squireno7
Junior Member
well I finally got the knobs and jacks all cleaned up and put some miles on it after 10 years. sounds like i remember it. I have a Boss GE-7 runnning through the loop and that really cleans up the tone. i have not done the tubes yet as I wanted everything working properly before I stick new tubes in. I just redid my Charvel. shield painted all the cavities, upgraded the wiring with silver wire. new on/on/on switch with a Dimarzio DP 100. took out a Bill Lawrence XL 500. the DP really screams. wow. series/single/parallel. with middle and neck pickups there is alot of tone options now. I think im gonna try the JJ tubes. I have read alot of different set ups here. what is your favorite with this style amp for pre amptubes?
Old 03-29-2011, 12:56 PM   #11
squireno7
Junior Member
how do you make big pics here instead of the small ones??????????
Old 03-29-2011, 01:27 PM   #12
royslead
Senior Member
royslead's Avatar
Welcome to the forum, squireno7; and yes, by all means, if you can afford to - KEEP that amp!!
__________________
Why do people list all their gear here?
royslead is offline   Reply With Quote
Old 03-29-2011, 05:46 PM   #13
squireno7
Junior Member
I believe i will now. got the knobs and jacks all cleaned up after ten years and it sounds good. time for new tubes though. trying to decide which ones i wiant. its for home use and I want more tone then volume.
Old 03-29-2011, 05:51 PM   #14
squireno7
Junior Member
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
