MarshallForum.com
Reply
Thread Tools Display Modes
Old 10-14-2008, 01:49 PM   #1
m3l
Junior Member
Input Jack Replacement
Hello Everyone,
I have a Marshall Valvestate VS30R. I've been having trouble with the input jack for awhile. I took the amp apart and found that one of the terminal pieces on the underside of the jack was missing and there was a slight burn on the PCB where it should have been. I was wondering if these types of stereo input jacks (1/4, I believe) are interchangeable. Some are offered at Radio Shack. But would I definitely need to get a marshall replacement ? And if so, where should I look to order it online ?
Thanks in advance.
m3l is offline   Reply With Quote
Old 10-14-2008, 03:55 PM   #2
m3l
Junior Member
Re: Input Jack Replacement
Any ideas ?
Old 10-14-2008, 05:36 PM   #3
Pie
Junior Member
Send a message via MSN to Pie
Any jack will do. If it's a guitar imput, you want a mono input.
EDIT: If there are any components attached to the jack, make sure you copy those over onto the new one.
Pie is offline   Reply With Quote
Old 10-14-2008, 06:22 PM   #4
m3l
Junior Member
So, as I understand it, there's the jack and then there's the actual housing for it which must be soldered to the PCB. And you're saying that for both of those any 1/4 mono replacement will do ? This is assuming that the replacement part also has 4 terminals.
Old 10-14-2008, 06:49 PM   #5
Mr Songwriter
I would do a Google shopping search for something like "1/4" mono jack socket pcb mount" and see if it returns anything that matches what you've got, if there's a brand name printed on the housing that might help. Make sure the pins match up with the holes on the PCB too.
Mr Songwriter is offline   Reply With Quote
Old 10-16-2008, 01:59 PM   #6
m3l
Junior Member
Does anyone know of any stores that would sell this component or a decent substitute ?
Old 10-16-2008, 02:31 PM   #7
m3l
Junior Member
I was told about another option. I can use a jumper wire to bridge the terminal and PCB gap for a temporary solution ? Is this just copper wire soldered to the end of the terminal ?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
