MarshallForum.com
Reply
Thread Tools Display Modes
Old 01-20-2011, 06:52 PM   #1
scat7s
V.I.P. Member
scat7s's Avatar
blue glow in vacuum tube
peeked in the back of my amp yesterday and noticed one of my rca 6v6's had a smallish spot of blue glow to it.
is this something i should be concerned about? i know ive read about this b4, but cant remember what the verdict was...it still sounds fantastic, but i did notice a faint pop now and then, nothing obnoxious, pretty subtle really. but a faint pop nontheless.
could these things be related?
scat7s is offline   Reply With Quote
Old 01-20-2011, 07:10 PM   #2
diesect20022000
V.I.P. Member
diesect20022000's Avatar
Re: blue glow in vacuum tube
no. large amounts will indicate ionization and slow tube death but, small amounts are normal.
Old 01-20-2011, 07:17 PM   #3
Alabama Thunderpussy
Senior Member
Alabama Thunderpussy's Avatar
Not at all. Blue glow is a common effect. If anything it can indicate a hotter bias. As I've understood it, it's a phenomenon that occurs when electrons and ions strike each other at high velocity inside the vacuum tube.
The glass envelope of the tube is actually very mildly conductive at high temperatures (inside the vacuum), hence the blue glow tends to gravitate towards certain areas of the bottle, as you'll notice. Sometime's it's just a spot, other times it's more of a fractal design.
Obviously, if you decrease the negative bias voltage (bringing it closer to 0, hence LESS negative) and more current is passing, more electrons are moving within the bottle and at a faster rate, hence more blue glow.
__________________
For your amps, ya dingus.
Alabama Thunderpussy is offline   Reply With Quote
Old 01-20-2011, 07:23 PM   #4
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
When tubes are made, they pull a vacuum on the tube. The better the vacuum, the better quality the tube. Once the vacuum is pulled a device inside the tube called a getter is activated. The getter splatters a barium laced stain on the tube (generally on the top). This leaves a shiny, mirror-like stain on the tube. The purpose of the getter is to further eliminate any extraneous air left in the tube. The effects of the getter last throughout the life of the tube. Even though all of these precautions are used, all the air cannot be completely removed. The small amount of gas in the tube will cause the light blue glow you see. It is harmless.
In current production tubes, there is a chance for more air (gas) to be inside the tube. Therefore the blue glow is even greater.
__________________
Old 01-20-2011, 07:30 PM   #5
scat7s
V.I.P. Member
scat7s's Avatar
great, thanks guys.
Old 01-20-2011, 09:54 PM   #6
RiverRatt
V.I.P. Member
RiverRatt's Avatar
Be very worried if the gas in the tube is glowing violet. That's a tube that's getting air in somewhere. Beam power tubes seem to be more prone to the blue glow. I think I have some pics of each.
Here's a dying 5Y3:
This is a pair of 5881s with the blue glow:
__________________
Quote:
Originally Posted by MartyStrat54 View Post
That's what I like about you Alan...you got it bad. You're a tube-aholic.
Quote:
Originally Posted by dreyn77 View Post
IT's JUST A MAGNET AND A WIRE!!!!!!!!!!!!!! GET OVER IT!!!!! BIG DEAL!!!!!!!! WOOHIPY!!!!!!!!
RiverRatt is offline   Reply With Quote
Old 01-21-2011, 03:16 AM   #7
big dooley
V.I.P. Member
big dooley's Avatar
Quote:
Originally Posted by Alabama Thunder***** View Post
Obviously, if you increase the negative bias voltage and more current is passing....
INcrease the negative voltage on pin 5 and you DEcrease the amount of electrons flowing to the anode... that's how it works
yes i like screwing ants
__________________
JVM, the only marshall that's been modded to tame it, instead of hotrodding it
big dooley is offline   Reply With Quote
Old 01-21-2011, 02:00 PM   #8
Rahlstin
Senior Member
Rahlstin's Avatar
I think the blue glow is cool. A budy of mine had a Mesa amp back in the late 80's that looked like a purple and blue plasma storm in the back of the amp. He used that thing for years and years that way with no troubles.
Rahlstin is offline   Reply With Quote
Old 01-21-2011, 06:53 PM   #9
Senior Member
YES!! Thank you for catching that. I meant voltage increase as in closer to positive. I should have said DEcrease.
Fixed.
Now, tell the fine folks here WHY increasing the negative voltage on pin 5 results in a decrease of electrons flowing to the anode. ;-)
__________________
Old 01-21-2011, 07:20 PM   #10
MM54
Senior Member
MM54's Avatar
It's more negative so it repels more electrons back towards the cathode (as like charges repel), preventing them from hitting the plate, or passing the plate and whacking their tiny little negative heads off the glass
__________________
-Matt
If you don't understand what I'm saying, assume I'm making a joke. Trust me.
Lachesky Amplifiers - Home of the CA10
Orders for 2013 CA10s are now being accepted!
"... And I come from a place
where they drag your hopes through the mud
because their own dreams are all dying"
MM54 is offline   Reply With Quote
Old 01-21-2011, 07:58 PM   #11
scat7s
V.I.P. Member
scat7s's Avatar
funny...
Old 01-21-2011, 08:00 PM   #12
MM54
Senior Member
MM54's Avatar
Hey, you'd be blue too if you smacked your head off a piece of glass a few billion times thicker than you while traveling at the speed of light
__________________
-Matt
Old 01-21-2011, 08:36 PM   #13
MajorNut1967
Senior Member
MajorNut1967's Avatar
well great the baboons are loose!
Old 01-21-2011, 09:37 PM   #14
MartyStrat54
V.I.P. Member
How about a misplaced circus chimp?
__________________
Old 01-22-2011, 03:40 PM   #15
FourT6and2
Senior Member
As others have said, blue glow is just an indication that there isn't a 100% vacuum inside the tube. That's normal. If the tubes glow blue while the amp is in standby, then you have a problem.
FourT6and2 is offline   Reply With Quote
Old 01-22-2011, 06:29 PM   #16
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
IMO the blue glow in a valve is one of the most badass things about them. Looks kinda eerie on some of them.
__________________
Jon Wilder
http://www.wilderamps.com
Old 01-22-2011, 07:58 PM   #17
demonufo
Banned
Mercury Arc Rectifiers;
Now THAT'S badass blue glow.
demonufo is offline   Reply With Quote
Old 01-23-2011, 02:25 PM   #18
scat7s
V.I.P. Member
scat7s's Avatar
it is very cool looking, beautiful color.
Old 01-23-2011, 04:41 PM   #19
topcat 70
Senior Member
topcat 70's Avatar
Quote:
YouTube - Hewittic Mercury-arc Rectifier of Manx Electric Railway
Ive seen a few of those Demon,mostly in old cinemas.I wouldnt want one to break if i was near it though!
topcat 70 is offline   Reply With Quote
Old 01-23-2011, 05:30 PM   #20
demonufo
Banned
Quote:
Duck and cover...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
