MarshallForum.com
Reply
Thread Tools Display Modes
Old 01-12-2011, 09:12 PM   #1
chuckmehh
Senior Member
chuckmehh's Avatar
Send a message via AIM to chuckmehh
soldering iron not getting hot
What's up guys? First and foremost, I'm a soldering noob, so ANY advice is greatly appreciated.
I got a cheapo iron from Radio Shack (not even sure of the voltage) and I had soldered some pickups in before with it and all that good stuff. Today, I went to take the pickups out of a recently acquired LTD EC-1000 and the tip isn't getting hot enough to melt the solder. The barrel is still VERY hot, but it's just not transferring to the tip. What do you think?
chuckmehh is offline   Reply With Quote
Old 01-12-2011, 09:23 PM   #2
MM54
Senior Member
MM54's Avatar
Re: soldering iron not getting hot
I use a cheapo 25W Radioshack soldering iron most of the time, works great.
Is the little screw that holds the tip in tight? Also, is the tip clean? If it's cruddy it may not be able to let the heat out.
__________________
-Matt
If you don't understand what I'm saying, assume I'm making a joke. Trust me.
Lachesky Amplifiers - Home of the CA10
Orders for 2013 CA10s are now being accepted!
"... And I come from a place
where they drag your hopes through the mud
because their own dreams are all dying"
MM54 is offline   Reply With Quote
Old 01-12-2011, 09:24 PM   #3
chuckmehh
Senior Member
chuckmehh's Avatar
I will tighten it, screw it, then clean it........and then I'll tend to the soldering iron
Old 01-12-2011, 09:31 PM   #4
MM54
Senior Member
MM54's Avatar
__________________
-Matt
Old 01-12-2011, 09:49 PM   #5
chuckmehh
Senior Member
chuckmehh's Avatar
I'm thinkin I just need a new tip. I dunno man it's just not even melting solder or getting hot. Any suggestions from anyone else of a better soldering iron to get or something? Mine is a 30 watt by the way.
Old 01-12-2011, 09:56 PM   #6
MM54
Senior Member
MM54's Avatar
My little radioshack one has been going string for a long time, for being cheap I think they're pretty well made (really, a soldering iron isn't complicated). I'd try a new tip, and then look for a new iron. If it turns out you need a new iron, you'll have a spare tip!
__________________
-Matt
Old 01-12-2011, 10:00 PM   #7
brp
Senior Member
brp's Avatar
Ya the screw(s) that holds the tip is always the first suspect. They loosen themselves from the expansion/contraction of constantly heating up and cooling down no matter how tight you turn them. Also it's often too easy to over tighten them and strip the threads
I have a few soldering guns, some highend ones and cheap ones, and the one that actually works best is a no-name chinese made one, because it actually has a compression fitting to hold the tip tight, rather than screws. I don't know why they all don't have that.
Next suspect is a dirty tip as MM54 said.
__________________
JMD:1 Believer
Recommended: On Floor Audio mods by HOT TUBES 70, Martimus Maximus tubes from MartyStrat54, NOS tubes from RiverRatt
-- My Studio --
"If we can't laugh at the dead, we have no business killing people"
brp is offline   Reply With Quote
Old 01-12-2011, 10:10 PM   #8
Micky
V.I.P. Member
Micky's Avatar
If the tip isn't tight, it can't transfer the heat...
__________________
Stupidity should be painful...
Marshall MHZ15, DSL40c, DSL5c, M4, 4X12 full stack, Gibson LP, VOX, Eminence, Celestion, Ovation, Fender & more...
Micky is online now   Reply With Quote
Old 01-12-2011, 10:19 PM   #9
chuckmehh
Senior Member
chuckmehh's Avatar
The tip is most definitely tight as an update. Still no go.
Old 01-12-2011, 10:33 PM   #10
Adwex
Super Moderator
Adwex's Avatar
Try sanding or filing the tip.
Also, try "tinning" the tip...melt a dab of solder on it, it helps transfer the heat. It also prevents the tip from oxidizing, which can impede heat transfer.
Old 01-12-2011, 10:39 PM   #11
thetragichero
Senior Member
thetragichero's Avatar
yeah i'm willing to bet it's an oxidized tip
__________________
'65 Guild M-65 | BC Rich Special X Mockingbird | Tele Build with Lydian Neck | too many partscasters | Fender Blacktop Jazzmaster | '85 Ibanez RB850 bass | Blacktop PBass partscaster build with JBass neck
'98 JCM 2000 DSL100 | Peavey XXX | Jet City PicoValve | Fender Excelsior | Orange Terror Bass | too many racks!
NOS Tubes, Eminence Speakers
Quote:
Originally Posted by charveldan View Post
I'm happy to pay my tech $40 buck to take the Zap for me.
Quote:
Originally Posted by smcgov View Post
can somone tell my how to drain caps, I got a pretty good jolt last night.
thetragichero is offline   Reply With Quote
Old 01-12-2011, 10:45 PM   #12
jcmjmp
Senior Member
1) The tip must be cleaned (paste cleaner)
2) You must tin the tip before using it
jcmjmp is offline   Reply With Quote
Old 01-12-2011, 10:53 PM   #13
Blisster
Senior Member
Blisster's Avatar
sand the tip a little so it has a slightly flat side and try that. I've had the same exact problem. Sometimes a larger gauge tip helps.
__________________
Marshalls: 1992 JCM 200 DSL 100, 2007 JCM 800 2203, 1998 Valvestate VS102r
Marshall Cabs: JCM800 1960b G12m-70s, JCM900 1960a G12T-75, 1960 BX Greenbacks
Other: MESA Engineering 1991 Dual Rectifier Solo "Pre 500", MESA Oversized Rectifier slant cab w/ V30s
Blisster is offline   Reply With Quote
Old 01-12-2011, 11:06 PM   #14
chuckharmonjr
Senior Member
chuckharmonjr's Avatar
Location: About as far south in Alabama as you can go without swimming
+1000000000000 Blisster...I would recommend sanding both sides with 40 grit to clean it..then tin it up
__________________
JCM2000 DSL100
JMD-1 100 Watter
JMP800 2204
Hughes and Kettner 18w
JTM 50
1960A
1960B
2061BX Clone
(2)Seismic Audio 2-12
Avatar V30 1x12
Joe B Sig Goldtop
Tobacco Burst Les Paul
Black Les Paul Custom
Honey Burst Les Paul
R8 Les Paul in Tea Burst
ES-175 in Cherry
EDS-1275 in White
Fender Strat in Tobacco Burst
http://soundcloud.com/chuck-harmon-1/woman
http://soundcloud.com/chuck-harmon-1/webs-and-dust
chuckharmonjr is online now   Reply With Quote
Old 01-12-2011, 11:25 PM   #15
brp
Senior Member
brp's Avatar
It also should be noted that sometimes cheap irons or guns just don't work worth a crap after a while. But it's likely a dirty/oxidized tip. Sometimes you just need a new one. Sanding can help for awhile though.
__________________
JMD:1 Believer
-- My Studio --
Old 01-13-2011, 01:19 AM   #16
diesect20022000
V.I.P. Member
diesect20022000's Avatar
yeah i'm thinking you just need to sand the tip or replace it. if nothing else works though take it back. I've got a 30 watt weller that i use and you need to remember to let it heat up for at LEAST 10 min first. the first time i tried soldering with it it didn't work right either and it was because it wasn't hot enough and because i didn't angle it properly. if you have the cone shaped tip on use the side of the cone NOT the tip. Good luck homie.
Old 01-13-2011, 12:19 PM   #17
thetragichero
Senior Member
get a weller gun off amazon
i think i paid less than 40$ shipped, and you can get the tips from rat shack for like a buck apiece
__________________
Old 01-13-2011, 12:23 PM   #18
splatter
Senior Member
splatter's Avatar
throw it away and go to home depot and buy a weller. I used radio shack irons before some are just sh!t . Sounds like you got one of those
__________________
Gibson Les Paul Axcess w/wcr darkburst
EBMM Axis x 2
76 Marshall JMP 2204 modded by Tim Crawford
Marshall YJM100
Marshall haze 40
Splawn 2 x 12
splatter is offline   Reply With Quote
Old 01-13-2011, 12:25 PM   #19
thetragichero
Senior Member
here you go:
Amazon.com: Weller WEL8200PK 120-Volt 140/100 Watts Universal Soldering Gun Kit: Home Improvement Amazon.com: Weller WEL8200PK 120-Volt 140/100 Watts Universal Soldering Gun Kit: Home Improvement
__________________
Old 01-13-2011, 12:31 PM   #20
poeman33
Super Moderator
poeman33's Avatar
Personally I wouldn't recommend the gun. Too many watts and too bulky. A 40 watt iron works much better for me. All the power to those who get good results with guns, but I never have.
Find a Weller 40 Watt Soldering Kit Torches & Soldering Irons from The Home Depot
__________________
CSA (Certified Strat Addict)
Quote:
Originally Posted by EL 34 View Post
poeman33 is a midget busker champion of ****-town ontario so he knows everything.
https://soundcloud.com/poe-man-1/king-bee-no-eq
poeman33 is offline   Reply With Quote
Old 01-13-2011, 12:35 PM   #21
MajorNut1967
Senior Member
MajorNut1967's Avatar
LOL I have never seen some jargon about soldering irons! First of all don't buy one of those big gorilla soldering guns for working on Amps & guitars. You don't need anything more a 30-35 watt Iron. If you are on a budget and in the US try here:
Stahl Variable Temperature Soldering Station
Old 01-13-2011, 12:36 PM   #22
thetragichero
Senior Member
100 watt soldering gun means you can get in, flow the solder, and get out quicker than with a low watt pencil
the quicker you take the heat off of whatever component you're soldering, the less of a chance you have to torch the component
rg keen agrees: How to Solder
the light on the front is damned convenient, too
__________________
Old 01-13-2011, 12:37 PM   #23
core
Senior Member
core's Avatar
I agree in the 40 watt iron, it'll give you much better heat for soldering pots and such. I had the same problem with my LP Custom, with my old 25 watt iron I couldn't get it hot unless I held it there forever. The 40 watt was the trick!
__________________
Aces & 8's
core is offline   Reply With Quote
Old 01-13-2011, 12:40 PM   #24
Ken
Senior Member
Ken's Avatar
Should you use a 100 watt iron on 100 watt amps and a 50 watt iron on a 50 watt amp?
I use the bulky gun, but I'm not working on amp PC's. I like the power, the light bulb and the reliability. It's better for working on my car as well.
Ken
__________________
1999 Marshall DSL 50
Late 1970's (?) Fender Champ
Marshall battery amp
PRO 4x12 from the 1970's
Woodson 2x12
1976 Les Paul Standard
Epiphone Les Paul knockoff
ESP Lawsuit Explorer
1979 Chiquita Travel Guitar
1995 Taylor 310
Ken is offline   Reply With Quote
Old 01-13-2011, 12:51 PM   #25
diesect20022000
V.I.P. Member
Ken
yeah. make sure to get acid core solder too. that's the bomb on live electrical components.
Old 01-13-2011, 01:00 PM   #26
Ken
Senior Member
Ken's Avatar
Quote:
LOL I've never even SEEN acid core solder! Who uses it anyway? And who sells it?
Ken
__________________
Woodson 2x12
1995 Taylor 310
Old 01-13-2011, 01:09 PM   #27
MajorNut1967
Senior Member
Man you guys are dangerous! LOL For those of you that use you grand dad's 100 watt gorilla soldering gun, "I want to see you solder some diodes without frying them or do you realize that when you are super heating a guitar POT with a gorilla gun that you are shortening the life of the pot?"
The key to soldering is a clean well tinned iron, clean parts and good solder. And if you got a tough job to solder use some solder juice. I can solder the earth lug to the chassis with a 30 watt iron no problem.
Old 01-13-2011, 01:22 PM   #28
core
Senior Member
core's Avatar
60/40 resin core solder.
__________________
Aces & 8's
Old 01-13-2011, 01:43 PM   #29
jcmjmp
Senior Member
Exactly. There are simple rules to soldering and I already stated them in my earlier post.
Old 01-13-2011, 01:45 PM   #30
Lespaulnmarshall
Senior Member
Lespaulnmarshall's Avatar
Get a weller 25w soldering iron and griffin solder.
__________________
1987x .Every guitarist should have experienced it at least once
Lespaulnmarshall is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
