MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 12-18-2010, 02:41 AM   #1
mike mike
Senior Member
mike mike's Avatar
front loaded vs rear loaded cabs
Hey guys. I just wanted to know the sound difference and the technical difference between front loaded and rear loaded cabinets. And In front loaded cabs, are the speakers closer to the grill cloth? Btw, I play death metal, and I like punchy articulat sounds. And I saw that ENGL and Diezel now do front loaded cabs
__________________
ENGL Invader 100
'92 2500 MkIII
MF400 cab
Vader 4x12
Ibanez RGD2127z
Gibson Explorer
'00 PRS Singlecut(pre-lawsuit)
'97 PRS CE22
mike mike is offline   Reply With Quote
Old 12-18-2010, 04:28 AM   #2
T-Bird
Senior Member
Re: front loaded vs rear loaded cabs
Hi.
Front loaded a is superior cab design, but in a case like Marshall cab grille cloth, unbelievably expensive to make.
The sound differences are none, if the construction is solid on both styles.
Regards
Sam
T-Bird is offline   Reply With Quote
Old 12-18-2010, 05:57 AM   #3
eddiegj
Senior Member
eddiegj's Avatar
Quote:
Originally Posted by T-Bird View Post
Hi.
Regards
Sam
I'm going to have to disagree with this. A friend had me check out his Peavey PA column. Sounded like the horn was out or something. It was a front load speaker enclosure with a velcro'd grill. The back to the cabinet was not removable. To get to the wires you had to reach in through the speaker holes. Seemed to be a real cheap way of making a cabinet. So... it is my belief that front loaded speaker enclosures can be made without a lot of additional expense. Further more it is my understanding that since front loaded speakers are mounted closer to the user/audience without having any deflection at all other than the grill cloth, the speakers should sound different. Weather they sound better or not is up to the person using them. I am guessing that the sound would be less laser like and fill the room better. Hey Marshall Cabs are ment for the big rooms.
__________________
Marshall JCM2000 DSL 100
1960a Cab (G12T-75)
1960b Cab (G12-65)
1936 2x12 Cab (V30-G12H)
PRS Custom 24
Kramer Pacer Deluxe
eddiegj is offline   Reply With Quote
Old 12-18-2010, 12:30 PM   #4
mike mike
Senior Member
mike mike's Avatar
thanks guys. but i doubt its a cheap way of doing it if the ENGL and Diezel cabs are made that way. and they probably both put out alot, i'm just not sure in sound differences.
huh look at this here. a diezel cab with the front baffle removed
__________________
ENGL Invader 100
'92 2500 MkIII
MF400 cab
Vader 4x12
Ibanez RGD2127z
Gibson Explorer
'97 PRS CE22
Old 12-18-2010, 05:36 PM   #5
eddiegj
Senior Member
eddiegj's Avatar
I didn't say your cabinet was cheaply made if anything I was dissing Peavey. Rock on dude with that killer cab.
__________________
1960a Cab (G12T-75)
1960b Cab (G12-65)
PRS Custom 24
Kramer Pacer Deluxe
Old 12-18-2010, 06:05 PM   #6
Marshall Mann
Senior Member
Marshall Mann's Avatar
Hey Mike,
I have a "Road" 4-12 made by Korg in the 70's that is front loaded. It is much more "punchy" than my rear loaded Marshall cabs, and carries a lot more bass response as well.
It is built like a brick sh*t house as well. It looks to be similar in build and dimensions to your Diezel.
__________________
Quote:
TwinACStacks "BTW: I AM going to own a 6100 sometime. Then I'm gonna mod the EVER-LOVIN' **** out of it....Just to piss these guys off.
Marshalls a Mesa and mostly Les Pauls
Marshall Mann is offline   Reply With Quote
Old 12-18-2010, 06:49 PM   #7
thrawn86
Senior Member
Quote:
Off topic a bit, but I have to take exception to this.
If ANY company can save money, especially a company that has become a little bigger, they will eventually find a way to cut costs and increase the bottom line. So if front loading saves them a few bucks a cab, it may become the norm....not something based on sound or sonic properties.
That being said, that cab looks great and I'm sure it sounds good. Only thing about front loaded cabs with no removable rear baffle is like eddie says: Harder to service perhaps if you need to get to wiring/jacks. Beyond that, if it sounds good, Rock It!
__________________
-Martimus Maximus Tone Packs - MHD Pickups - OFA Pedals-
thrawn86 is offline   Reply With Quote
Old 12-18-2010, 09:04 PM   #8
mike mike
Senior Member
mike mike's Avatar
right on bro. yeah they also make a rear loaded cab. they are the same price, but they say good things about the Front Loaded version
__________________
ENGL Invader 100
'92 2500 MkIII
MF400 cab
Vader 4x12
Ibanez RGD2127z
Gibson Explorer
'97 PRS CE22
Old 02-06-2013, 11:38 PM   #9
alhayesmusic
Senior Member
alhayesmusic's Avatar
If things are equal equal - I REPEAT - IF ALL THINGS ARE EQUAL, then rear loaded offers more mid scoop, tighter lows. Front offers more mid punch. If you look at the cabinet designs from the 70's and 80's (I'm old enough to have seen them), the cabinet designers started to go rear loaded when metal started to rise in popularity. Several boutique makers will offer both depending on the sound you are after, the speaker used, etc. The difference, like most "sound preferences," is completely subjective. Some makers, like KMD, made cheaper cabinets with front loaded speakers. They could put stamped steel, round, grill covers on the front, seal the rear baffle, and hide the fiber board construction of the cheap cabs. I used to claim to prefer front loaded. Now I just listen to the cab. If I like it, then I buy it. Stay warm in New England! Have a great week, everyone!
alhayesmusic is offline   Reply With Quote
Old 02-06-2013, 11:40 PM   #10
alhayesmusic
Senior Member
One last note. Sealing the rear panel is not a cheaper way to make cabinets. It does, however, allow for the cabinet to be sealed tighter from the factory, and, if the handles are sealed well and the front baffle is well made, then the speaker cab should be TIGHT.
Old 02-07-2013, 02:24 AM   #11
mariosoldano
Senior Member
mariosoldano's Avatar
hi
it is not cheaper do make a front loaded cabinet.
it is easier to change a speaker from a front loaded cab (only 4 screws)
it is easier to mic it because you see the speaker
it sounds the same
mariosoldano is offline   Reply With Quote
Old 02-07-2013, 03:35 AM   #12
mickeydg5
V.I.P. Member
mickeydg5's Avatar
Also some things to add.
Hi-Fi speakers are mostly front loaded.
Like Mariosoldano mentioned, front loaded speakers are easier to access.
And Alhayesmusic, front loaded cabinets are sealed better.
The problem is that most guitar speakers come with premounted front gaskets which means rear loading. In order to front load these speakers it would cost to special order gasket (kits) or special order rear gasketed speakers for front loading. There are some manufacturers that supply both front and rear gaskets for either type of mounting.
mickeydg5 is online now   Reply With Quote
Old 02-07-2013, 09:42 AM   #13
GIBSON67
Senior Member
GIBSON67's Avatar
With rear loading, I think more sound is transferred through the wood thus giving a fuller sound. And to it's easier to make because you don't have to make a separate grill baffle.
And that baffle rattles around sometimes if not done properly.
GIBSON67 is online now   Reply With Quote
Old 02-13-2013, 06:04 AM   #14
lowinput
Banned
I hear a difference with the 1960DM from utube clips. could it be that they have turned the amp up?
lowinput is offline   Reply With Quote
Old 02-13-2013, 08:27 AM   #15
metromutt
Senior Member
I've always felt one of the biggest tonal differences with front load was the fact that the steel chassis sits on the baffle wood as opposed to a cork gasset. Try putting your guitar against a door and strum, then sling a mag between both. Don't try it with a mag full of hooters though.
metromutt is offline   Reply With Quote
Old 02-13-2013, 08:34 AM   #16
zenfly
Senior Member
zenfly's Avatar
I say anyone who thinks they can actually hear a difference should get right to the cork sniffer thread and confess..
http://www.marshallforum.com/backsta...niffer-if.html
__________________
Marshall JTM45 Mk2/GEC KT66
Mojotone JTM45/Siemens NOS el34,
Marshall Mosfet 100 / 1965a
Marshall MG15dfx,
Marshall 2045(Sourmash Clone)1973 Creamback
Fender 59 5f1 Champ,
Fender 57 5e3 Deluxe,
Fender 63 Vibroverb,
Fender 67 Super Rev
Fender 91 Vibroking.
Dr.Z Maz18
too many guitars..
Jim Marshall 1923-2012 "Leo" Fender 1909 1991
zenfly is offline   Reply With Quote
Old 02-13-2013, 07:21 PM   #17
lowinput
Banned
metromutt, I just got a front loaded cab, and the speakers have the cork on both sides of the metal frame. I guess they made the speakers better back in 1974.
Old 02-15-2013, 06:11 PM   #18
Hillcountry
Senior Member
Hillcountry's Avatar
You can mount speakers from the rear just not in public.
__________________
Amps:
Matchless Clone with KT66
Matchless Clone with 6V6
36 watt TMB clone EL34
Guitars:
Custom 59 LP Copy
1984 Les Paul Studio
Custom Tele Jr. Single P90
Current board:
Germanuim Fuzz Clone
Germanium Rangemaster Clone
Hillcountry is offline   Reply With Quote
Old 02-15-2013, 07:46 PM   #19
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
Boy, I must have missed this thread in 2010, but I have to say both the old and current comments are really, really bad.
Some of you are actually stating that 3/4 inch difference in the speaker placement makes a sonic difference.
And like Mickeydg5 said, if a speaker is front mounted, it has the appropriate gasket. They do not mount the speaker without a gasket.
Some of you guys are smoking some really good pot.
__________________
Old 02-16-2013, 12:41 AM   #20
Lyv2Ryd
Senior Member
Lyv2Ryd's Avatar
Its alot easier to put your screwdriver thru the cone while front mounting. It sucks!! For that reason alone I like rear loading
__________________
"A man's got to know his limitations" - Clint Eastwood
Guitars
GIBSON: Les Paul R8, Les Paul Standard, Les Paul 50s w/P90s, Explorer '76, Firebird V - FENDER: American Strat SSS, American Strat HH, Custom Tele w/P90s - PRS: Custom 22 -
Amps
Original Marshall JCM 800 2203 - JTM 45 - Peavey Classic 30 - Bogner Shiva - Fargen Olde 800 - 5e3 Deluxe
...and many pedals and cabs
Lyv2Ryd is offline   Reply With Quote
Old 02-16-2013, 03:55 PM   #21
MartyStrat54
V.I.P. Member
Now that's a valid point.
__________________
Old 02-16-2013, 04:12 PM   #22
mickeydg5
V.I.P. Member
mickeydg5's Avatar
That is true. If only we lived in a perfect world.
Aluminum cones for everyone!
Old 02-17-2013, 10:29 AM   #23
lowinput
Banned
The 1974 Peavey 612H cab is front mounted and it has SO MuCH more wide spread of tone than marshall has ever done with their inferior 'speaker only' cab design.
Marshall at 5 degrees, full tone. Peavey at 90 degrees, full tone.
Old 02-17-2013, 10:32 AM   #24
lowinput
Banned
They are still putting out these 'historical', 'old fashioned', speaker only cabs. Horns amd speakers were being used back in the late 60's! why marshall? lazy?
Old 02-17-2013, 03:48 PM   #25
MartyStrat54
V.I.P. Member
What Marshall guitar cab has a horn driver?
__________________
Old 02-18-2013, 01:07 AM   #26
lowinput
Banned
None! so that means marshall is inferior sound!
Old 02-18-2013, 01:35 AM   #27
Lyv2Ryd
Senior Member
Lyv2Ryd's Avatar
Sounds more like an arguement for open or closed back cabs
__________________
Guitars
Amps
Old 02-19-2013, 12:42 AM   #28
MartyStrat54
V.I.P. Member
Have you ever seen a frog swim backwards???
__________________
Old 02-19-2013, 06:40 AM   #29
Micky
V.I.P. Member
Micky's Avatar
What?
__________________
Stupidity should be painful...
Marshall MHZ15, DSL40c, DSL5c, M4, 4X12 full stack, Gibson LP, VOX, Eminence, Celestion, Ovation, Fender & more...
Micky is online now   Reply With Quote
Old 02-21-2013, 10:24 PM   #30
Lyv2Ryd
Senior Member
Lyv2Ryd's Avatar
Quote:
Originally Posted by Micky View Post
What?
Exactly !!
__________________
Guitars
Amps
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
