MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 12-08-2010, 06:46 AM   #1
jake59slp
Junior Member
Wire Gauge
Hey my fellow guitarists
A few months ago I built a 4x12 replica Marshall 1960B cab, with celestion vintage 30s. I love them and think they sound awsome.
When I built the cab I put cable in that wasnt very thick becuase I was using a 15watt head. But this week I have a 1959SLP that I ordered, and I want to re-wire the cab for some thicker wire to handle the 100w head. I have read about how different gauges effect sound quality, resistance and load. Also that it can damage the amp if its having to do extra work.
Im just wanting to know what the best gauge to use, ive heard 12, 16 and 18 are good gauges, I know that to check the gauge you have to measure the thickness, but is it the thickness of the actuall copper wire or the measuring from the complete thickness with the plastic insulator included?
I live in england, so im not sure weather it will be SWG or AWG.
Thanks guys .
Rock on.
jake59slp is offline   Reply With Quote
Old 12-08-2010, 02:16 PM   #2
Kunnz
Senior Member
Kunnz's Avatar
Re: Wire Gauge
14 AWG is good enough, that is the same as 1.5mm.
__________________
'Sleeping is a waste of time'
Kunnz is offline   Reply With Quote
Old 12-08-2010, 02:56 PM   #3
Adwex
Super Moderator
Adwex's Avatar
Re: Wire Gauge
It is the thickness of the wire conductor itself that's important, not just the overall thickness of the wire + insulation.
As Kunnz said, 14 AWG is good. 16 AWG would probably be good enough, but 14 is a good upgrade. 18 AWG would be too small.
Old 12-08-2010, 04:20 PM   #4
jake59slp
Junior Member
Re: Wire Gauge
Thanks guys , I think ill play it safe and go with 14, is that whats used in real marshall cabs?
Its set my mind at ease now because i didnt want to damage my new amp head by having the wrong gauge,
Thanks.
Old 12-09-2010, 10:38 AM   #5
Adwex
Super Moderator
Adwex's Avatar
Re: Wire Gauge
I'm pretty sure Marshall cabs come with 16 AWG from the factory.
Old 12-09-2010, 04:35 PM   #6
jake59slp
Junior Member
Re: Wire Gauge
Ive just taken the back off my 4x12 and it has 18gauge AWG, i built the cab my self but I used a real marshall jack plate on the back and that has 18ga, so im wondering if marshall use 18 gauge then surely it will be ok to re-wire my cab with it? Also im wondering if the jack plate wires have 18ga would it be pointless wiring it with something thicker when the current will still have to pass through the 18ga anyway?
Old 12-09-2010, 06:24 PM   #7
george76
Senior Member
george76's Avatar
Re: Wire Gauge
14 AWG is the stuff I use for 4x12's. Its definitely thicker than the standard marshall wire, which is probably 16 or 18. If you go any thicker than 14AWG you would seriously struggle to solder it onto the speaker terminals, it would just be too big.
george76 is offline   Reply With Quote
Old 12-09-2010, 06:56 PM   #8
jake59slp
Junior Member
Re: Wire Gauge
Think I might play it safe and use what marshall use at 18, I could always upgrade, if I know the 100w heads can cope with 18ga then thats ok for me
Old 12-09-2010, 07:07 PM   #9
Adwex
Super Moderator
Adwex's Avatar
Re: Wire Gauge
Using 18 is not playing it safe, using something heavier is. Marshall uses 18 because it is cheaper.
Use whatever you want, even though we suggest 14.
Old 12-09-2010, 07:51 PM   #10
jake59slp
Junior Member
Re: Wire Gauge
The only thing that put made me want to go back to 18, was i read that it can damage the transformer if you use thicker cable becuase "it adds more load" I dont really know about this stuff, but I spent alot of money on my head I just wanna make sure it doenst get damaged, if 14 will be good for my head then I will use it, does it matter if i use 14 and the jack plate cables are still 18?
Old 12-09-2010, 07:54 PM   #11
thetragichero
Senior Member
thetragichero's Avatar
Re: Wire Gauge
i'd reckon you'd have a better chance of destroying the transformer if the thin cable broke and you had NO load
__________________
'65 Guild M-65 | BC Rich Special X Mockingbird | Tele Build with Lydian Neck | too many partscasters | Fender Blacktop Jazzmaster | '85 Ibanez RB850 bass | Blacktop PBass partscaster build with JBass neck
'98 JCM 2000 DSL100 | Peavey XXX | Jet City PicoValve | Fender Excelsior | Orange Terror Bass | too many racks!
NOS Tubes, Eminence Speakers
Quote:
Originally Posted by charveldan View Post
I'm happy to pay my tech $40 buck to take the Zap for me.
Quote:
Originally Posted by smcgov View Post
can somone tell my how to drain caps, I got a pretty good jolt last night.
thetragichero is offline   Reply With Quote
Old 12-09-2010, 08:02 PM   #12
jake59slp
Junior Member
Re: Wire Gauge
Looking at the charts for the gauges, I think theres only something like .60mm of a difference between 18 and 14 anyway, i guess there isnt much in it
Old 12-09-2010, 08:10 PM   #13
Adwex
Super Moderator
Adwex's Avatar
Re: Wire Gauge
Quote:
Originally Posted by jake59slp View Post
....i read that it can damage the transformer if you use thicker cable becuase "it adds more load" ...
Where did you read that rubbish?
Old 12-09-2010, 08:13 PM   #14
jake59slp
Junior Member
Re: Wire Gauge
Just on google, I mean i dont have a great knowlage, but i would imagine using a thicker cable would make less work for the transformer, as wouldnt the cable have less resistance if it was thicker?, Ill go with the 14
Old 12-10-2010, 03:40 AM   #15
george76
Senior Member
george76's Avatar
Re: Wire Gauge
14 or 16 is fine id say for a 4x12.
14 is a bit thicker than most people are using in their cabs, but I think its the best option.
Old 12-10-2010, 05:10 AM   #16
jake59slp
Junior Member
Re: Wire Gauge
ok so i have a marshall jack plate on my cab and the wires that came with it are 18ga, would it matter if i took those off and put my new wires directly onto the jack plate?
Old 02-11-2011, 02:20 PM   #17
yes9310
Junior Member
Re: Wire Gauge
I've heard that thinner wire gets better mids and highs were heavier wire sounds too dark. For example 18-20 Gauge will sound better than 14 Gauge. Makes sense that a heavier wire would tend to over saturate the tone. The really old cabs from mid 60s used 20 Gauge I've heard and those sounded pretty darn good to Jimi's ears and mine!
yes9310 is offline   Reply With Quote
Old 02-11-2011, 03:22 PM   #18
MajorNut1967
Senior Member
MajorNut1967's Avatar
Re: Wire Gauge
Okay I see a lot of recommendations and no reasons behind the recommendations will give you a little bit here. I just did some tests with the help of my daughter so you guys can see the actual amount of current going through the wires on a 412 Marshall cabinet.
First test was what that recent 20 W amp I built: minimum current was .077A maximum current was 1.347A
Second test 100 W JCM 800: minimum current was .093A maximum current and this is with a gain booster pedal (+ 12db) was 4.2578A.
So the maximum current wires going to the speaker with my daughter banging away on her Les Paul at the volume on the guitar maxed only yielded about 5 amps of current max.
With that knowledge what gauge wire is needed to carry 5 amps of current safely over the short distance of the speaker cables? Here are some examples of the max current wire gauges can carry and not in a sustained load:
Gauge 110V 12V
22 5 5
18 10 10
16 13 20
14 17 40
12 23 60
Old 02-11-2011, 03:32 PM   #19
Clammy
Senior Member
Clammy's Avatar
Re: Wire Gauge
Wow, a bit of of misinformation here... the thicker the wire, the less resistance it will have. With regards to the output transformer, that's irrelevant anyway, because the load is the combined impedance of the speakers. Thicker wire is a better conductor (allows more of the input power to reach the speakers) and will also heat up less (less chance that it burns up), so it's a better choice. It has zero effect on tone (unless you're running super long lengths of wire, which will have increased capacitance. But why would you do that when wiring a cab? Use the shortest lengths feasible).
The really old cabs sound good due to the speakers, materials and construction, NOT the wire used inside them.
Cheers!
__________________
MARSHALL FOR LIFE!!
Clammy is offline   Reply With Quote
Old 02-11-2011, 03:37 PM   #20
MajorNut1967
Senior Member
Re: Wire Gauge
Cheers!
A+
Old 02-11-2011, 07:53 PM   #21
thetragichero
Senior Member
Re: Wire Gauge
i must be a masochist.... i wired mine with 12 awg
__________________
Old 02-11-2011, 08:12 PM   #22
MajorNut1967
Senior Member
Re: Wire Gauge
Quote:
And how many watt is your amp? LOL
Old 02-11-2011, 08:19 PM   #23
thetragichero
Senior Member
Re: Wire Gauge
i'm thinking i might need to build that 1kW amp that other dude was talking about now!
__________________
Old 02-11-2011, 08:27 PM   #24
Clammy
Senior Member
Clammy's Avatar
Re: Wire Gauge
Well, that certainly won't hurt anything. Musta been a pain to solder, though!
Cheers!
__________________
MARSHALL FOR LIFE!!
Old 02-11-2011, 09:18 PM   #25
thetragichero
Senior Member
Re: Wire Gauge
tell me about it!
plus it was parallel/series in a front-loading cab that my cats kept climbing in
__________________
Old 02-11-2011, 10:12 PM   #26
brp
Senior Member
brp's Avatar
Re: Wire Gauge
Quote:
lol wat?
Um... no it doesn't.
And we're talking about a maximum of about 18 inches of wire here right?
14 or 16 is the playing it safe route.
__________________
JMD:1 Believer
Recommended: On Floor Audio mods by HOT TUBES 70, Martimus Maximus tubes from MartyStrat54, NOS tubes from RiverRatt
-- My Studio --
"If we can't laugh at the dead, we have no business killing people"
brp is offline   Reply With Quote
Old 02-11-2011, 11:02 PM   #27
chuckharmonjr
Senior Member
chuckharmonjr's Avatar
Location: About as far south in Alabama as you can go without swimming
Re: Wire Gauge
Holy dog**** matiLda...did I actually read that stupid bull**** correctly?...Wire guage size between your head and your cabinet affects TONE? Who the hell is the idiot that said that? Bottom line=use a wire guage big enough to handle what your amp puts out...bigger is better....jeez.....read Ohms law for ****'s sake. E=IR. It dont get any simpler than that. The only way wire size will affect your precious 'tone' is if you way undersize and the **** melts in two and blows your output tranny.
__________________
JCM2000 DSL100
JMD-1 100 Watter
JMP800 2204
Hughes and Kettner 18w
JTM 50
1960A
1960B
2061BX Clone
(2)Seismic Audio 2-12
Avatar V30 1x12
Joe B Sig Goldtop
Tobacco Burst Les Paul
Black Les Paul Custom
Honey Burst Les Paul
R8 Les Paul in Tea Burst
ES-175 in Cherry
EDS-1275 in White
Fender Strat in Tobacco Burst
http://soundcloud.com/chuck-harmon-1/woman
http://soundcloud.com/chuck-harmon-1/webs-and-dust
chuckharmonjr is offline   Reply With Quote
Old 02-11-2011, 11:05 PM   #28
Clammy
Senior Member
Clammy's Avatar
Re: Wire Gauge
Quote:
Now, would you say that is a NEGATIVE effect on the tone???
Cheers!
__________________
MARSHALL FOR LIFE!!
Old 02-11-2011, 11:48 PM   #29
chuckharmonjr
Senior Member
Re: Wire Gauge
Cheers!
Just slightly Bro...lol
__________________
JCM2000 DSL100
JMD-1 100 Watter
JMP800 2204
JTM 50
1960A
1960B
2061BX Clone
Avatar V30 1x12
Joe B Sig Goldtop
ES-175 in Cherry
EDS-1275 in White
Old 02-12-2011, 12:15 AM   #30
brp
Senior Member
brp's Avatar
Re: Wire Gauge
Actually, no, you didn't. The claim was that the gauge between the jack plate and the speaker affects tone, no less!
__________________
JMD:1 Believer
-- My Studio --
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
