MarshallForum.com
Reply
Thread Tools Display Modes
Old 09-13-2008, 04:52 PM   #1
thelalimmey
Junior Member
Is the Marshall TSL 122 combo unreliable?
Hey
I was seriously considering buying this amp but then I read a few things about the amp being unreliable (the pedal too). Are people overstating these problems ? The amp sounds pretty great but i can't be bothered with hassle...Anyone?
thelalimmey is offline   Reply With Quote
Old 09-13-2008, 08:05 PM   #2
rob717
Junior Member
Re: Is the Marshall TSL 122 combo unreliable?
I have a JCM200 TSL 122, I bought it back in 2002. It sounded great when it was working. But one time I was playing at my last gig, the T4A fuse blew. I tried replacing the fuse a few times with the same kind but kept on blowing. I tried replacing the ECC83 and EL34 tubes but the T4A fuse keeps on blowing. Something is shorting out the in circuitry for sure. I just don't know it yet until I start poking around with the rectifier circuit. Yikes, so far I have spent $48 for a 4 sets of EL34 and another $56 for ECC83 without having it fixed yet.
In short, I definitely will not recommend to anyone buying this amp unless you got money to throw away. Oh BTW, I can attest to the foot switch that came with it is so unreliable. I have used it for about 2 years but it quit working. Someone have mentioned in one of the forums to replace the cable with a CAT5 but I haven't tried it yet. I will let you know if this works.
rob717 is offline   Reply With Quote
Old 09-13-2008, 08:14 PM   #3
stock_hippie
Senior Member
doood...reliablity is the name of the game....in my opinion
stock_hippie is offline   Reply With Quote
Old 09-14-2008, 05:03 PM   #4
thelalimmey
Junior Member
k guys ..thanks for the input. I'm gravitating towards a dsl now. Less stuff to wrong and I haven't read any bad reviews...cheers
Old 09-19-2008, 05:28 AM   #5
DaveAngel
Junior Member
DaveAngel's Avatar
I've got a TSL122
Been good upto about 6 months ago when i had to replace the power supply and power valves together - smelt like it was overheating then just started poping fuses. I guess a dodgy PSU can happen anywhere.
Other than that its been pretty good. Takes a good 30-40 mins to warm up enough to get the really creamy tones. I've heard alot of complates about the cable to the foot switch being pulled and snapping the PCB inside (due to lack of connector on the foot switch itself, i can see its possible, but you have to be unlucky or treat it bad for that to happen.
DaveAngel is offline   Reply With Quote
Old 03-03-2009, 09:01 PM   #6
EL34
Junior Member
I have owned a TSL122 since 2004. I am an authorized service tech for KORG/Marshall. The main problem with this amp is that the customers try to fix the amp on ther own. If you are not a trained and certified electronics technician then you have no business messing with this amp. It has lethal voltages and circuitry that you will not understand. The only problem that I had with mine is that one of the output tubes failed and blew the HT fuse. From my training I knew better than to start pumping fuses and tubes into the amp. I have worked on many of the TSL amps. The second problem is abuse. This is an expensive amp, the amp dose not like to have drinks poured into it, the foot controler dose not like to be drug across the floor and equipment racks rolled over the cord. I have found only few reoccurring problems that an authorized service center can easily repair for not allot of money.
EL34 is offline   Reply With Quote
Old 03-04-2009, 02:36 AM   #7
Webslinger
Senior Member
Quote:
Originally Posted by EL34 View Post
I am an authorized service tech for KORG/Marshall. The main problem with this amp is that the customers try to fix the amp on ther own........... I have worked on many of the TSL amps. The second problem is abuse. This amp dose not like to have drinks poured into it, the foot controler drug across the floor and equipment racks rolled over the cord..... I have found only few reoccurring problems that an authorized service center can easily repair for not allot of money.
Yes, no amp likes abuse, but the things you mentioned...arent those common mishaps for the environment a working Marshall lives in? Many other Marshall models suffer the same abuse & stand up to it much better.
I like the TSL122 for its features and had wanted one, but after doing some web-research was scared off by the stories of component failures NOT due to abuse..... on amps that never left the home. Of all fairly-recent Marshall models, none seems to have as bad a reputation as the TSL122. Many times were mentioned replacement of transformers & PC boards. I wouldnt call those easy/inexpensive reapairs. I also read where the owners were told off-the-record by the techs that TSL122's were difficult to work on for some reason.
How long was this model in production compared to other production-runs? When it was finally discontunued, weren't many suppliers selling them off seriously discounted. And I've seen many "one-owner" used ones on places like eBay & Craigslist a little more than a year old (just out of warranty?), for less than half of the new price. Not a good sign.
I also seen more than a few for sale that had extensive upgrades and/or components replaced with aftermarket bands. It would seem those amps had to have had alot of parts thrown at the problem to finally get it right. And these were done by experienced techs. I think most owners of tube/transformer technology equip know the dangers, and whats beyond thier capability. These specimens would probably explain amount of the "hot-rodded" ones out there.
So all that's why many people think there must be a design flaw with this particular model. Granted, there are some that work perfectly and I expect some owners to respond accordingly. But even at around $700 (US) used, thats too much of a gamble for me.
Webslinger is offline   Reply With Quote
Old 03-04-2009, 05:56 AM   #8
DragonSarc
Senior Member
DragonSarc's Avatar
+1 --------^ thats why i got rid of mine since it started acting up I had it fixed and it wasnt the same after that, even the tech that i sent the amp to he said he gets TSL almost 3x a week for repair
__________________
JVM410H w/ 1960 Vintage A & Lead B
Egnater Renegade 65 w/ 1936 cab
Gibson LP Custom Classic Cream
Gibson LP Standard Ebony
Gibson LP Studio Heritage Cherry Sunburst
Gbison LP Special Vintage Burst w/ APH 11 Pro
Gibson LP studio faded mahagony w/ Burstbuckers Pro V
Gibson LP Studio 50's Tribute Humbucker
Gibson SG Classic
Edwards Les Paul w/ Duncan JB and 59's
Fender Am Std Strat w/ Vintage Noiseless
LTD EC-500 w/ EMG-X 81/85
Jackson Stealth Pro MIJ
DragonSarc is offline   Reply With Quote
Old 03-04-2009, 06:36 AM   #9
pavs
Senior Member
pavs's Avatar
Funny then!! my TSL is the only one that has been reliable since 2003??? I dunno I guess I'm lucky.
I've rehearsed and gigged it and is just the best amp I have ever owned...
Cheers
__________________
_______________________
2011 AFD100
1936V
\m/
pavs is offline   Reply With Quote
Old 03-05-2009, 03:42 PM   #10
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
Exclamation Re: Is the Marshall TSL 122 combo unreliable?
I have a basement full of Marshall amps. I bought a "used" TSL122 in 2003. All the knobs were there, but it was missing parts off of the rear grille. Someone had made their own holes in the bottom for casters. Appearance wise, this amp was about a 6 or 7, so it had seen it's share of abuse. (Definitely not a studio amp.)
I took it home and it played perfectly. I've since put two Eminence Man O' War's in it (now runs an 8 Ohm load). I have a huge inventory of used and NOS tubes as I wheel and deal on Ebay. I put 4 Siemens (W. Germany) EL34's into it and a hand selected 12AX7 for the PI tube (V4). I put RCA and GE's into V1, V2 and V3. I also installed the special rubber rings on the tubes to reduce microphonics. This is a good idea when you run a combo and the amp is in the same space as speakers putting out 110dB. This amp is one of the best sounding Marshalls that I own. It has a super clean channel, thanks to the upgrade with the NOS U.S.A. tubes. The Siemens power tubes cost 140 for a used set, but they were a matched quartet and tested at 88 to 90 on my calibrated 707 tube tester. Much better sounding than any of the current EL34's (a whole topic on its own).
Conclusion: This combo was abused before I got it. However, it still worked perfectly. I've done what could best be described as normal maintenance and the amp is still serving me well. I'm sorry to hear about all of these various TSL problems. I have (2) TSL602's (same treatment with tubes as the 122) and a TSL100 (like brand new...perfect). I did have a 1999 DSL401 that I never had any problems with and sold it on Ebay for $450 and bought a NOS DSL401 from a music store for $495 (ya, that was a smoking deal). I believe it was a 2006 model. The last year they were made?)
My experience has made me stay clear of the DSL 50 and 100 watt heads. I have read more about their problems than any other Marshall amp. Especially the early DSL's. (Even the early DSL401's had a variety of maladies.) I buy 800's, 900's and TSL's. Some stay and some go. I only keep the amps that show the most potential. Like a beautiful girl, some Marshall amps just feel special when you are bending a G string through them...and others don't.
Old 03-05-2009, 04:27 PM   #11
Ken
Senior Member
Ken's Avatar
Quote:
Originally Posted by MartyStrat54 View Post
My experience has made me stay clear of the DSL 50 and 100 watt heads. .
I bought a DSL 50 head because here and other places the TSL's reliabilty was frequently mentioned as an issue. Prices on eBay and Craigs List bare that out: TSL's are often cheaper than DSL's.
I have not seen a lot about problems mentioned with the DSL except the reverb. I bought mine used for $500 and the guy said the reverb was dodgy. Well, the thing rattled when I carried it!! I opened it up and saw one of the small springs holding the tank was broken at the end; all I had to do was reattch it. Reverb is now great.
I've only had the amp a month, but so far it's been great. What kinds of other problems are common to the DSL 50 head?
Ken
Ken is offline   Reply With Quote
Old 03-05-2009, 08:18 PM   #12
GerryL98
Marty, PM me if you're interested in trading one of your TSL602's for my 2004 TSL122. Mine's mint...just way too loud for a practice amp.
GerryL98 is offline   Reply With Quote
Old 03-05-2009, 09:07 PM   #13
MartyStrat54
V.I.P. Member
KEN-I just want you to know that what you have heard (especially on Ebay) is 180 degrees from what I have heard. That is, 50 and 100 watt DSL's have electronic problems, usually associated with heat. There was a guy in just the past few days that was selling his DSL100 and he made a point telling bidders that he had all the problems fixed and the head was ready to rock. Right here in this forum are players asking for help with their DSL's. I want to make something clear. I'm not a critic. For one thing, if any Marshall had a whole lot of problems we would all know it. I think each model has it's share of problem children. Thankfully, I have yet to buy a Marshall that didn't deliver night after night. However, we all know that not every Marshall is solid. It's the law of manufacturing. For every X amount you produce, there will be X amount that will fail.
People tend to forget that tube amps were made in the 30's and reached their peak in the 60's. We are all lucky that certain tubes remain or they are being manufactured simply for us tube freaks. Quote: Today's tube amps are made to sound good with the currently available tubes. That's right, you can get a real fat sound using Russian or Chinese tubes. Now that's an engineering feat all by itself. However, tubes make heat and a lot of it. Combo's are by far harder on the electronics than a head. In a head, the heat naturally dissipates to the top and the tubes are mounted right-side up. Marshall provides openings in the head to allow cool air to come in and the hot air goes out. The metal chassis does not get hot and neither does the guts inside of the amp. A combo on the other hand has the chassis mounted upside down. The hot air builds up in the upper part of the cabinet. (Now Marshall tries to reduce this by having a three-piece back grille that has one solid piece and two dot matrix, perforated metal pieces.) However, the heat is still a problem and the chassis gets hot and by the third set the guts are up to 200 degrees. Heat destroys electrical components. It also affects the circuitry as the amp goes from start up to being on four hours. We all have heard that some Marshall have gotten so hot as to melt the PCB and cause the solder to melt. Now you're talking around 385 degrees.
I bring all this up, because that's why the tube amps went away. They got too hot and people got hurt touching them. They are brutally heavy. (Oh they also had something called HIGH VOLTAGE!) When I set a combo on stage, I give it plenty of clearance on the backside. I use a whisper fan to keep air moving around through it. This keeps the killer heat monster away.
In closing, I think most of the problems that people complain about regarding their Marshall amps were caused one way or the other by an overheating incident. I say this, because most owners complain of multiple problems. If you get a car motor hot, think about all the different things that you might have to replace. The same holds true for your Marshall amp. Treat it right and it will treat you right.
Old 03-05-2009, 09:26 PM   #14
MartyStrat54
V.I.P. Member
Quote:
Gerry-Thanks for your interest. Right now I'm not interested in trading any of my 602's and I already have a tricked out 122. I will say that I use the 602's more than the 122, because they saturate quicker at lower volume levels. I do a lot of business on Ebay and a 602 in sharp condition is bringing between $650 and $725 (plus about $55 to ship). The first thing I do is take out the Wolverine speakers and put in JBL D123's. What a sound! A pair of them in good to mint condition will bring $170 to $260 dollars, but they are by far the best sounding guitar speaker. Maybe you can sell your 122 locally and then try and buy one on EBAY. Just a thought.
Again, thanks for you interest and good hunting.
For those of you that are interested, I have a web site. It is:
MUSICIAN'S AUDIO EQUIPMENT-MAKERS OF VERSACAB
Old 03-06-2009, 06:29 PM   #15
joshuaaewallen
Senior Member
joshuaaewallen's Avatar
... tubes make heat and a lot of it. Combo's are by far harder on the electronics than a head. In a head, the heat naturally dissipates to the top and the tubes are mounted right-side up. Marshall provides openings in the head to allow cool air to come in and the hot air goes out. The metal chassis does not get hot and neither does the guts inside of the amp. A combo on the other hand has the chassis mounted upside down. The hot air builds up in the upper part of the cabinet. (Now Marshall tries to reduce this by having a three-piece back grille that has one solid piece and two dot matrix, perforated metal pieces.) However, the heat is still a problem and the chassis gets hot and by the third set the guts are up to 200 degrees. Heat destroys electrical components. It also affects the circuitry as the amp goes from start up to being on four hours. We all have heard that some Marshall have gotten so hot as to melt the PCB and cause the solder to melt. Now you're talking around 385 degrees.
I bring all this up, because that's why the tube amps went away. They got too hot and people got hurt touching them... When I set a combo on stage, I give it plenty of clearance on the backside. I use a whisper fan to keep air moving around through it. This keeps the killer heat monster away.
Speaking of the heat monster... Is it practical to install a fan of some sort to get air moving inside the combo? I have thought about this in the past because my TSL122 combo does seem to get pretty darn hot, but it always plays and sounds great so I haven't done anything about it yet. What are your thoughts?
__________________
Josh
-2004 PRS Custom 24 10 Top (Sustainiac System w/ Duncan Alnico II bridge PickUp)
-Epiphone Explorer
-1999 Marshall JCM 2000 TSL (Wilder Amplification mods)
-Marshall G15RCD
-Martimus Maximus Preamp Tone Pack (Rollin' With Da Homie's)
-ElectroHarmonix .44 Magnum
-PRS Dallas 120 2x12 Vintage 30's
-Digitech RP1000
joshuaaewallen is offline   Reply With Quote
Old 03-06-2009, 09:03 PM   #16
MartyStrat54
V.I.P. Member
I have custom mounted fans in every tube amp "combo" that I have ever owned since 1976. Some of the older fans were not very quiet and they ran to fast (prop noise). Nowadays, you can get a small computer fan and they are very quiet. It only takes a little air movement to defeat heat build up. I have a 240 volt whisper fan on my 122 that is hooked up to 120 volts. This causes the fan to run at half speed and makes it even quieter. (Not all 240 volt fans will run on 120. Make sure it will if you go this route.)
Love the split power section with the Yellow Jackets and EL-84's.
Old 03-07-2009, 08:25 AM   #17
joshuaaewallen
Senior Member
Re: can you give some advice
Quote:
Originally Posted by uvwx985 View Post
hi,this is my new site,can you give some advice :-)ffxi gil
Advice on what?
__________________
Josh
-Epiphone Explorer
-Marshall G15RCD
-Digitech RP1000
Old 03-07-2009, 04:58 PM   #18
joshuaaewallen
Senior Member
Hey there MartyStrat54! Thank for your input on the fan. Mind if I pick your brain a bit more on the subject? I would like to know if you have any specific suggestions on:
1. What fan might be the best fan to select for this purpose?
2. How best to mount the fan (ie. in the metal grill on the back of the amp? Top? Bottom? Side? Etc.)
3. Can this be done utilizing the amps power supply, or would it be better to give the fan it's own, entirely separate power supply?
Any suggestions, and especially illustrations and pictures, are most appreciated!
__________________
Josh
-Epiphone Explorer
-Marshall G15RCD
-Digitech RP1000
Last edited by joshuaaewallen; 03-07-2009 at 05:04 PM. Reason: adding a url to the referrence of the THD Yellow Jackets
Old 03-07-2009, 05:43 PM   #19
MartyStrat54
V.I.P. Member
I'm sorry, but I do not have any pictures at this time. However, on the Marshall combos, I mount a cooling fan onto the upper dot matrix grille. I use a Tubeaxial brand, model number 5912-5656S. They are expensive, around 80 bucks (cheap insurance). They are 240 volt fans that I run on 120 volt. This cuts the RPM in half and the fan noise is down to around 28dB and that is quiet. I mount the fan so it is pushing the hot air out and sucking cool air in from the bottom. On these fans, there are indicators that show the direction of the blade and the direction of the air flow. I hook the fan up to the power switch. The fan comes on when the amp is on. If you are handy with a soldering iron and heat shrink tubing, you can get this mod done in around three hours. You can use a 120 volt fan, but they usually are as loud as 60dB. A computer fan will work with 120 volts and is quiet, but you need to find one that pushes some CFM. Ask if you have any other questions.
Marty
Old 03-08-2009, 11:57 AM   #20
joshuaaewallen
Senior Member
... You can use a 120 volt fan, but they usually are as loud as 60dB. A computer fan will work with 120 volts and is quiet, but you need to find one that pushes some CFM...
Yeah, I thought about using a computer fan, but it seems like it just wouldn't push enough air through for my thinking. I will have to do some homework and look into Tubeaxial fans. That may just be the way to go. I had not thoughts of directing the fan to push air out of the cab. That's good thinking. It makes sense to pull heat away and thus cycle cooler air to the area the heat is leaving. Thanks Marty! When I finally get around to tackling this I will definitely let you know how it goes.
Thanks again, I really appreciate your input!
__________________
Josh
-Epiphone Explorer
-Marshall G15RCD
-Digitech RP1000
Old 03-08-2009, 07:11 PM   #21
MartyStrat54
V.I.P. Member
I was busy yesterday when I posted the above info. I did want to tell you that there is more to this installation. Most importantly you will need some rubber washers that go between the grille and the fan. This will isolate the fan unit and prevent excessive "whine" from the fan. I use four, 8/32 type bolts. These are small enough in diameter to go through the holes in the Marshall grille without any drilling. Put the head on the outside and the nut and lock washer on the inside.
You will need to drill a small hole in the bottom of the chassis. You will have to have the chassis pulled to determine where you can make the drill hole. It is best to make the hole oversized and then install a rubber grommet in it. Then you can pass the power cable through this hole over to the power switch. One wire will go to ground and the other goes to the "ON" switch. Make sure it is the right connection. You want the fan to come on when the switch is turned on.
I usually use stranded 16 gauge wire and that is plenty big for this application. I try to use just the right length of wire so that the excess just hangs without touching anything. (Attaching the wire to the grille may transfer fan noise.
Most of these fans have bare soldering terminals. You will want to use heat shrink tubing on these connections to prevent any possible shock from occurring. There may be some other little tweaks I do, but that depends on the individual amp. Sometimes I try different rubber washers to get the quietest mount. If your fan is below 35dB, that is really good and quiet. Let me know if you tackle the job. Just remember, these type of fans now come with a noise listing. Any fan of the proper size will do, just pay attention to the noise rating.
On a side note: If you had all four tubes replaced with YJ's, the heat problem would be a lot less than with EL34's in place. I notice that the YJ's have quite a long base to them and of course the EL84 is a much smaller tube and therefore it puts out a lot less heat. I do not think you would even need a fan if you were running a quad of YJ's with EL84's.
Marty
Old 03-09-2009, 01:12 AM   #22
Webslinger
Senior Member
I figured there was, thanks for adding the details. I was also considering some sort of cooling fan, myself and have some other questions and ideas on this.
Have you done an A - B comparison with a thermometer? With and without the fan? Just how effective in heat reduction would this be?
Evacuating the heat from inside the combo's case can be compared to an older full-size PC tower. There was usually an "entrance vent" of about 8sq inches, and there was the cooling fan mounted in front of similar sized exhaust vent. So inside airflow would follow a specific path, expelling heat through the fan while drawing-in cool air thorugh the intake.
Ok now what would happen is that people would (for any number of reasons) remove several of the rear expansion-card slot-covers, and/or leave the side access cover loose or off completely. What would happen was that even though the fan was running, the processor would still overheat. Why? Because of all the open areas, the fan was no longer baffled and just cavitating, and the "flow" of air was not moving from the intake to the exhaust port. (and this is why newer PC cooling fans are now mounted directly over the processor, with a duct-shroud. )
So anyway, I can see this same principle applying to a guitar amp.
I'll agree its probably better than having no fan at all, ...and your installation instructions are good & solid. But Im wondering.. with an open back amp (or even with the vented-solid-vented panels), Im not sure a PC fan (or similar electronics cooling fan) mounted the way you describe doing a whole lot..... unless it was a fairly good size, lets say at least a 4" blade fan? But then returns the question of Db level... not to mention any small RF field-hum from the motor that the amp might pick up. I know some amps already have a cooling fan, but I havent had a chance to look at one close enough to see how they have it designed as far as airflow.
Maybe a small cooling fan mounted to blow cool air directly AT the tubes might be better? Maybe with it's own battery for anyone who's unsure about tapping into the 120v (or 240v) onboard power?
Old 03-10-2009, 04:10 AM   #23
DragonSarc
Senior Member
DragonSarc's Avatar
lolz hahaha
question: doesnt the tube has to be hot to sound good? putting a fan to cool it down wont affect the sound?
__________________
Gibson SG Classic
Old 03-10-2009, 07:20 AM   #24
joshuaaewallen
Senior Member
Quote:
Originally Posted by DragonSarc View Post
lolz hahaha
Anyone here please correct me if I am wrong, but...
Basically just like a car tends to break down when it's a 100 degrees out, heat is also the enemy of electronics.
My understanding has always been that the tubes basically have filaments to heat them to where they should be temperature-wise for optimal operation, thus the glow, plus w/ the juice flowing throw them if they are working biased properly, and just plain working right, the tube temp isn't the issue. It's what the heat from all those tubes lined up inside the amp can eventually do to harm the other electronic components inside the amp that be be the problem...
That being said, if I am wrong about this anyone here please feel free to correct me.
__________________
Josh
-Epiphone Explorer
-Marshall G15RCD
-Digitech RP1000
Last edited by joshuaaewallen; 03-10-2009 at 07:23 AM. Reason: spelling and grammer... bad!!! ;) ..still bad...
Old 03-10-2009, 06:56 PM   #25
MartyStrat54
V.I.P. Member
That's 100 per cent right. In my hardcore gigging days, I played many an outdoor show with the temperature looming in the low 50's. The tubes are working just fine in this weather. Correct? So, cooling your tubes with room temperature air is not going to take them down to meat locker levels. All electronics have an upper and lower temp range that they can work in. I don't think Jim Marshall thought someone would try playing one of his amps after it sat out all night in minus 10 degree weather. You have to be realistic. The same for the hot side and playing in Phoenix and it is 115 degrees outside. We had fans on everything and you could hear it through the P.A. You ever hear of something called "thermal runaway?"
Conclusion: It's not so much taking heat off of your tubes as it is the buildup of heat on the chassis. A fan (four-inch BTW) mounted as I have described will cut the temp on the chassis. (In my old Peavey Mace with six, 6L6GC's, I had a really cool fan mod and I also installed a giant heat sink with thermal paste and rivets to the chassis. Of course I was in the Air Force and had access to all sorts of parts.) Anyway, a fan mod is not going to alter the sound of your tubes.
It's also nice to know that I have modern computer equipment, as I have a fan mounted on top of my processor (HP a350n with special Pentium 4 processor and 3G of RAM and a HP dv5000 laptop). Wouldn't know what to do without them.
And guy's here's another tidbit. There are some really quiet personal fans on the market. Take one of those and place it behind the amp. If you're not recording, it will do the trick and you don't have to do anything to your amp. I do things to my amp, because I can't help myself. I like the one-of-a-kind amps. I took the black grille cloth off of my 602's and put Marshall cane grilles on them with gold Marshall logo's. (Let me tell you that cane material is a PITA to work with.)
Well you are all a great bunch of guys and I really like this forum.
Marty
Old 03-13-2009, 07:06 PM   #26
joshuaaewallen
Senior Member
Cheers
Diddo... Mine was made in '99, and is a two owner amp. The bloke who hd it before me bought it new, gigged and recorded with it w/ no trouble. I am owner #2 and granted I really don't play out, it has given me no problems either.
__________________
Josh
-Epiphone Explorer
-Marshall G15RCD
-Digitech RP1000
Old 05-06-2010, 10:24 PM   #27
Kirk5443
Junior Member
Any company that engineers an amp with a suppression cap in the output stage that is barely rated to survive in that circuit(500pv cap rated at 500v)is total bs that is a fine example of designed engineering for failure cause when that cap shorts it takes your tubes and possibly your output tranny.being a repair tech I have seen it happen 7 out of 10 times its ridiculous I will not buy any modern Marshall made ever again
Kirk5443 is offline   Reply With Quote
Old 05-07-2010, 12:43 PM   #28
Webslinger
Senior Member
Ok, here's some questions, but you are the guy to ask...
I can understand, trying to cool with already hot outside or room temp may not make sense. But the output of any fan drops the temp by at least 10-15 degrees, so isnt that better than nothing?
Did you hear the fans buzzing being picked-up by the mics? Or was it an a hum caused by the electro-magnetic field, of a fan's motors.
And if so, would that be from being too close to an amp/PA, or a 60cycle feedback through the house power circuit, if the fan is plugged into the same outlet or powerstrip?
I heard of it but not exacty sure what it is.
It's not so much taking heat off of your tubes as it is the buildup of heat on the chassis. A fan (four-inch BTW) mounted as I have described will cut the temp on the chassis. It's also nice to know that I have modern computer equipment, as I have a fan mounted on top of my processor.
So if you were to install a 4" fan in an amp, whats the best way to do it;
A- place the fan to blow air directly onto the the tubes & chassis?
or
B- place the fan to blow outward, evacuating heat by pulling cool air through the case, as is done in a computer tower. Although Im not sure this would work very well with an open-back amp. You' probabaly have to seal the back, then install an "inlet vent" opposette the fan. This might end up being hotter than just leaving the back open?
And then whats the best way to power the fan?
Isolated batteries?
Splice into the AC power wire before the transfomer?
Splice into the DC output past the transformer?
And do any of the amps circiut chassis have some sort of auxillary power connection, that a fan could utilize (like on a computer's motherboard?)
I probably wouldnt do this myself, I take it to a tech, but Im curious?
Old 08-14-2011, 09:52 AM   #29
craigbeal
Junior Member
I've got a 2004 TSL122 which I have had from new...
Played 100's of gigs with it now (7 years worth of road use) and never ever had a problem with it! No valves replaced, no services, no dodgy foot switch.. nothing!
Wonder if mine had a newer version main board however?
craigbeal is offline   Reply With Quote
Old 02-14-2014, 05:52 AM   #30
bludolph1
Junior Member
Hi, i had the same problems as most poeple with this amp and it has cost quite a lot of money in repairs/valves/fuses, the main problem always seemed to be that it over heats very qickley-buzzes and bangs! KNOW WHAT I MEAN
Sounds incredibly obvious but after two years of trouble i decided to put a standard desk fan 30cm away on low speed and guess what, no more problems.please try- i am at the moment touching wood as i have probably just cursed myselfFan obviously facing towards the back panel
bludolph1 is offline   Reply With Quote
Reply
Tags
marshall combo, tsl, tsl 122
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
