MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 09-01-2010, 09:07 AM   #1
Stratguy
Senior Member
Tone difference between a 1960 A & B cab?
Is there much tone difference between these two cabs - they are both loaded with celestion 75's. I'm kinda thinking the B might be a little bassier only because of the straight front which obviously gives it a little more square footage / volume? Thanks
Stratguy is offline   Reply With Quote
Old 09-01-2010, 09:16 AM   #2
IbanezMark
Senior Member
Re: Tone difference between a 1960 A & B cab?
I have an A and a B, both with essentially the same speakers.
The B has more bass response, but the angle on the A makes it a little clearer/easier to hear when practicing.
When I have to choose between the two, I usually pick the B because it sounds a little fuller.
IbanezMark is offline   Reply With Quote
Old 09-01-2010, 09:20 AM   #3
wkcchampion
Senior Member
wkcchampion's Avatar
It only gives a small difference in the room. None when close miked
__________________
Marco
http://pregnosplatter.altervista.org/index.html
The Brown Sound is HERE: http://www.marshallforum.com/cellar/...ally-here.html
Marshall gear :
- JMP-1 midi valve preamp
- 1981 JCM800 1959 SuperLead
- 1983 JCM800 2203
- 1987 Silver Jubilee 2555
- 1969 Basketweave replica with Celestion Pre-Rola G12M 25W T1221
Guitars: 2008 Parker Fly Mojo, 1995 Fly Deluxe "Eldy", 1959 pre-CBS Strat and 1993 ObG 1959 Les Paul replica
wkcchampion is offline   Reply With Quote
Old 09-03-2010, 03:32 AM   #4
Led4thehed2
Senior Member
Led4thehed2's Avatar
In my humblest of opinions, the difference between these two cabs in IMMENSE! I found the A cabinet to be "bitey" and far too sharp for my tastes. I know they're something like the best selling guitar 4X12 in the world, or so it might seem, but the B cabs have a very different tone that plenty of metal heads prefer. Plenty of 'em play Bs exclusively.
The B cabinet offers smoother, creamier distortion that was less sharp and yes, different bass response. Your tastes might dictate otherwise, but I'd strongly suggest you try 'em both and see which you prefer. Whichever one you end up choosing, I think you'll find the differences to be considerable.
Now go, and rock.
__________________
"If you don't play Gibson and Marshall you're a wanker!"
-Ian St. Ian
Led4thehed2 is offline   Reply With Quote
Old 09-03-2010, 12:02 PM   #5
nedcronin
Senior Member
nedcronin's Avatar
I agree the B's have a much more pleasant tone as well as more bass....
__________________
Check out my Marshall Amp Lovers facebook page if you facebook....click below
Click Here if you love Marshalls!
Come Join the TSL Tribe!
nedcronin is offline   Reply With Quote
Old 09-03-2010, 12:07 PM   #6
Australian
V.I.P. Member
Australian's Avatar
"B" cabs are it.
__________________
Thank You
Marshall Heads
1971-JMP 1959
1977- JMP 1959
1982-JCM800 2203
1989-JCM800 2205
Silver Jub 2550
30th Ann-6100
2007-JVM410
Super JTM/100JH
2008-1959RR
JMD-1
Marshall cabs
1982AJH+1982BJH--White A/GT75's+B/V30's--30th Ann-B-G12T75's
JCM800 A+B/preRolas-- AHW+BHW-- AX+BXClassic/G12M's-- Classic/G12h30's
JCM800 B/G12-65's--1936/V30's --1936/G1265's
Australian is offline   Reply With Quote
Old 09-05-2010, 12:00 AM   #7
DPTONE5
Senior Member
DPTONE5's Avatar
I've had A's and B's. I only play B's now for the same reasons others have stated.
__________________
Marshall Amps - 1987XL, JCM 800 2203X, 2555 Jubilee, 6100
Cabinets - 1960BX, 1960B JCM 900, 1936
Guitars - Fender American Deluxe Strat, Fender Clapton Strat, Jackson SL-1, 91' Gibson LP Classic, PRS Custom 24, Taylor 410-CE, Fender Highway One P Bass
Pedal Board - Boss Tuner, Fulltone Fulldrive II Mosfet, ReIssue Ibanez TS-808, Ernie Ball Volume Pedal to amp in. Loop - Boss Chorus, MXR Carbon Copy, Lee Jackson Mr. Springgy, Boss GE-7 EQ (Monte Allums Mod)
DPTONE5 is offline   Reply With Quote
Old 09-05-2010, 04:26 AM   #8
Landshark
Senior Member
Landshark's Avatar
Well... I must just have a humdinger of an A cab... Although it is a Laney and it's loaded with WGS ET-65s. I run it with an 80s 1960B with original G12T-75s... and the B cab is thin which I attribute to the G12T-75s (even though they are orgininal 80s speakers and they are supposed to have a more aggressive mid range then the current ones), and is used strictly for tight bass responce. The Laney is the tone king with FAT mids, but the low end is not quite tight enough.
Just my experience.
__________________
Shawn
'98 JCM 900 SL-X
Sourmash 4x12 (WGS ET-65s)
2008 Gibson Les Paul Studio
Revolving Door of Pedals including:
Out Front - Dunlop Crybaby, "On-stage" Tuner, Boss SD-1 Overdrive, Boss NS-2 Noise Suppressor. Loop - Boss RV-5 Reverb, Ibanez Tonelock DE-7 Delay.
Alvarez Acoustic-Electric
Landshark is offline   Reply With Quote
Old 09-05-2010, 07:51 AM   #9
charveldan
Banned
Location: Somewhere with a Friedman Marshall & Les Paul.
Angles work fine, i think there is too much emphasis on straight cabs.
charveldan is offline   Reply With Quote
Old 09-05-2010, 09:46 AM   #10
TubeStack
Senior Member
TubeStack's Avatar
There is a huge difference in sound between the two.
I prefer B cabs, by far. As others have said - more bottom end, fuller sounding, chunkier, more "together" feeling.
I also don't like the way A cabs blast you in the face. And I found that in certain rooms, they shoot too much sound toward the ceiling and cause a lot of nasty, treble-laden reflections that exaggerate the upper-range characteristics of the tone.
__________________
"And I'm sorry but I can't be kind about this, if you are bitching about "my Marshall is too loud" or "I need a hot plate or a PowerBake to manage the volume," then you don't need or deserve a Marshall all valve amplifier! ... You're like a guy that goes and buys 1970 Chevy SS 454 with 500 horse power and then puts his golf clubs in and drives around the golf course at 3MPH..." - MajorNut1967
TubeStack is offline   Reply With Quote
Old 09-05-2010, 11:02 AM   #11
Salsg
Senior Member
Salsg's Avatar
The B cab I used to own had less bass than my A cab, could have been the speakers.
I prefer A cabs because I want a better sound dispersement.
As an audience member, I prefer hearing A cabs because the guitarist usually hears him(her)self better. Instead of getting all the treble blast of icepick because the guitarist is only hearing off-axis tone, if they hear it at more ear level, it's usually better for the audience in the direct line of the speakers' beam.
__________________
Problem with this forum is for every one that knows what's up there are three with his head up his ass. It's just not worth it here
Politically Correct is another way of saying "mental disorder"
Salsg is offline   Reply With Quote
Old 09-05-2010, 12:43 PM   #12
T-Bird
Senior Member
Hi.
^^THIS^^ times 100000.
Applies to us bass players as well .
It's the audience that always comes first, never forget that if You want to be succesful.
If You're just wanking, then it's your choice of course, but don't blame the audience for their lack of understanding.
Regards
Sam
T-Bird is offline   Reply With Quote
Old 11-05-2010, 06:33 AM   #13
joemarshalljmp
Senior Member
joemarshalljmp's Avatar
Thats why when I play a half stack a or b I always bend down on sound checks to here what it sounds like in front of the speaker or stand out in the audience, I do agree that in my house my b cab is bassyer. A full stack is great But I have made myself about deaf because of the cab at my head and could not here myself sing, so sometimes I have been known to turn the top cab backwards just be careful of the angle because you can project too much sound at the drummer.
joemarshalljmp is offline   Reply With Quote
Old 11-05-2010, 08:20 AM   #14
dread1
Senior Member
dread1's Avatar
I dig the B cabs. Fuller
dread1 is offline   Reply With Quote
Old 11-05-2010, 08:52 AM   #15
Ken
Senior Member
Ken's Avatar
+1
The A is brighter, the B more resonant. Both together is really killer; you can't get that stage sound without using both. I use just the B more often than not, but if I had some roadies I'd use the full stack no matter how small the place!
Ken
__________________
1999 Marshall DSL 50
Late 1970's (?) Fender Champ
Marshall battery amp
PRO 4x12 from the 1970's
Woodson 2x12
1976 Les Paul Standard
Epiphone Les Paul knockoff
ESP Lawsuit Explorer
1979 Chiquita Travel Guitar
1995 Taylor 310
Ken is offline   Reply With Quote
Old 11-05-2010, 04:13 PM   #16
TheLoudness!!
Senior Member
TheLoudness!!'s Avatar
I have both and I think the "B" cab sounds much fuller.
__________________
"You gonna eat your cornbread???"
TheLoudness!! is offline   Reply With Quote
Old 11-05-2010, 04:18 PM   #17
Frankie
Senior Member
Frankie's Avatar
The huge difference between the two is normally that nobody plays an A cabinet (see all the above posts) so the speakers are never broken in when you plug into one.
In the case of a JCM 800 1960A vs. B, they have totally different speakers, so yeah the A'll sound way different.
__________________
"Motorhead meets the Ramones and NY Dolls."
Frankie is offline   Reply With Quote
Old 11-06-2010, 05:59 PM   #18
nedcronin
Senior Member
nedcronin's Avatar
Frankie I dodn't know they have different speakers in the JCM 8oo A's & B's....I have a JCM 800 B cab with G12M-65's in it. I LOVE this cab. What did they use for speakers in the A Cabs? I think mine is from 81 or 82.
__________________
Old 11-07-2010, 08:41 PM   #19
yladrd61
Senior Member
yladrd61's Avatar
I see a lot of guys lay the top A cab on its side at gigs
yladrd61 is offline   Reply With Quote
Old 11-08-2010, 10:39 AM   #20
Frankie
Senior Member
Frankie's Avatar
Quote:
Usually I see 65's in the A cabs and 75's in the B cabs. That's how Pop's '87 JCM800 cabs are. I guess Marshall was as inconsistent as always since your B cab has 65's in it.
__________________
Old 11-18-2010, 10:03 PM   #21
Ayrton
Senior Member
Ayrton's Avatar
For those that feel the A cab is too bright, try turning it on the side.
I have both, and generally prefer the sound of B cabs, however I would never go without having at least one A cab.
Ayrton is offline   Reply With Quote
Old 11-19-2010, 12:22 AM   #22
Clammy
Senior Member
Clammy's Avatar
My favourite cabs are early 80s JCM800 1982B (I have 2, and a model 1984B cab which is essentially the same thing, but without the "JCM800" badge) cabs loaded with Rola Celestion G12-80 sporting 444 bass cones. VERY full sounding, but not woofy in the bottom end, and great frequency response across the spectrum. They sound phenomenal with guitar AND bass through them!
I also have an early 80s JCM800 1982A cab with the same speakers, and it sounds great too, but is missing some of the "body" the B cabs have.
Cheers!
Clammy is offline   Reply With Quote
Old 11-19-2010, 01:04 AM   #23
Wycked Lester
Senior Member
Wycked Lester's Avatar
I always use a full stack of 2 B's live, usually just the top speaker on though. I can get buy with much lower stage vol that way.
__________________
I have a bunch of amps and guitars...
My favorite head ever - 2203
Second favorite head - Jubilee
My #1 Guitar - 98 Custom Shop Jackson Soloist-Mike Shannon Built
My #2 Guitar - 1982 Les Paul Std.
I dig blues and metal.
"IF IT'S TOO LOUD, YOUR TOO CLOSE"
Quote:
Originally Posted by Fretboard View Post
Personally, I'd never get another person's signature guitar, amp, etc. So, I'd go with the Jackson. I'm planning on getting an RR-1.
Wycked Lester is offline   Reply With Quote
Old 11-19-2010, 03:16 AM   #24
rockinr0ll
Senior Member
The slants always sound fuller to me, but the straight cabinets have low end that I prefer.
rockinr0ll is offline   Reply With Quote
Old 11-19-2010, 06:05 AM   #25
blues_n_cues
V.I.P. Member
blues_n_cues's Avatar
i've had both up on saw horses side by side & the B cab sounded more full to me.
__________________
LIFE,LIBERTY,& the pursuit of TONE.
2007 Epi LP Custom LTD.
1991 Jackson DK-2 HSS
2010 Austin LP GT w/ P90s
custom rebuilt Washburn BT-2 Maverick
Marshall JMP-1 (rack)
Marshall CODE 100 (eventually) lol
a bunch of other carp
my music,sounds,samples,& snippets-
http://www.reverbnation.com/rlcltd
https://soundcloud.com/rlc-ltd
Stratisfied
https://soundcloud.com/rlc-ltd/stratisfied
just riffing
https://soundcloud.com/rlc-ltd/just-riffage
blues_n_cues is offline   Reply With Quote
Old 11-19-2010, 08:52 AM   #26
Ken
Senior Member
Ken's Avatar
Cheers!
Sounds like we have the same stack! And I like them better than the G12T-75's for the reasons you state, although I DO like them too for metal.
Ken
__________________
Woodson 2x12
1995 Taylor 310
Old 11-20-2010, 05:18 AM   #27
Landshark
Senior Member
Landshark's Avatar
I want to just put a little disclaimer on my last post. I like the sound of the B cab best with two 75s and two 65s. That Laney slanted cab got really treblie on me over time... Nothing like running both A and B cabs together though!
__________________
Shawn
'98 JCM 900 SL-X
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
