MarshallForum.com
Reply
Thread Tools Display Modes
Old 08-13-2008, 05:03 PM   #1
byljer
Senior Member
byljer's Avatar
Question Tubes and Dickey Betts
Hi everybody!
I'm just wondering if anyone here know what kind of tubes Dickey Betts uses in his Marshall 1987 reissues?
I'm searching for the "Betts tone". I have a Gibson LP Standard 2007 model with the BetSet pu's from WCR Pick Up's ("handmade" by Jim Wagner after studying a set that Betts used a long time ago) and WCR's wiring kit to go with it. My amp is (you guessed it...) a Marshall 1987 reissue. I have gotten real close to Betts tone by changing the pu's, but I'm thinking about replacing the stock tubes since they're crap (two of them blew after one month, and I didn't drive the amp hard or use it very often).
Any tubeish suggestions?
byljer is offline   Reply With Quote
Old 08-13-2008, 11:14 PM   #2
stryker59
Senior Member
stryker59's Avatar
Re: Tubes and Dickey Betts
i dont know what dickey used but i really like JJ's
__________________
you've been weighed, measured, and found wanting!
stryker59 is offline   Reply With Quote
Old 08-13-2008, 11:47 PM   #3
st.bede
Senior Member
st.bede's Avatar
nice gear....not trying to pirate the post but let me suggest to you the, my les paul forum Les Paul Forums - MyLesPaul.com since you own a nice LP and I would love to hear all about your WCRs being an owner of WCRs myself (DB/GW)....
__________________
Peace: is not the lack of dischord but an active process that transforms the present dischord into harmony through reverence
"to criticize without vision is to be complicitious with dominance" Carolyn Casey
"Go easy and, if you can't go easy, go as easy as you can" Jennifer Stone....(from KPFA Cover to Cover)
st.bede is offline   Reply With Quote
Old 08-13-2008, 11:56 PM   #4
st.bede
Senior Member
st.bede's Avatar
again, here is something I found you might find interesting:
BG: One of the things that you are known for is your tone.
DB: Well you know the Lansing speakers have a lot to do with it and I don't use any distortion at all. I just use the natural distortion. If I can overdrive the tubes in the amp that's what I try to do. I put the amp just loud enough to overdrive the tubes in the amp.
from
Dickey Betts Interview
and more:
BG What do you have done to the amps?
DB They just bias the tubes and tune it with a little more treble. I don't beef them up or anything.
BG So they are totally stock?
DB Yeah. Totally stock. Like I said, the cabinets aren't stock, they have JBL 120's in them.
BG Didn't you cut half of the backs out?
DB You know sometimes I do cut just one third out of it like a twin amp. The ones that I am using now do not have the backs cut out. For outdoors you don't want to do that. You want solid backs. If you are playing a club or a theater, it's nice to have the backs cut. Actually Jerry Garcia turned me on to that. Just take one-third out of the middle. What it does is it kind of flowers the sound up on stage. It makes it kind of come up on stage, instead of shooting it straight out. Of course outdoors, you want to get the sound out there in front of you.
I also found out that there is a forum for Betts... Dickey Betts & Great Southern :: Where Music Plus Friends Equals Family
I hope that helps and if you find out about the tubes (or anything interesting) I would sure like to know
__________________
Old 08-14-2008, 03:00 AM   #5
byljer
Senior Member
byljer's Avatar
Thank you very much!
I've seen all the interviews with Betts about his equipment, and like all great artists he doesen't know to much about what's in his amp He thinks he uses a stock Marshall 1987 reissue. Yeah, right! I've seen pictures of his amp, and he's even got his name printed on the front of the amp. That amp is not stock. I bet it's made espesially for him at the Marshall factory, and that it's handwired.
The JBL Lansing he's talking about is the E120. They don't make'em anymore, but a good substitute would be Beymar Liberty-8. Check them out! Looks good! I'll get some of those....someday....when I'm filthy rich
Anyway, I'll keep searching for the tubes.
Thank you for the links! I'll check it out
Old 08-28-2008, 04:47 AM   #6
byljer
Senior Member
byljer's Avatar
Found this chap Doug who runs a web site called Doug's Tubes. To achive the Betts tone, he recommended the following:
Go with the RUBY EL34BSTR's. In the preamp, a Tung-Sol reissue 12aX7 in V1, Penta Labs 12AX7 in V2 and a JJ ECC83S in V3.
As you can see, he combines different brands of tubes. I'll let you know how it turns out when I've received them and installed them.
Old 05-03-2009, 10:14 PM   #7
JohnRussell
Junior Member
Just reading about your recommended tube selections for the Dickie Betts sound way back in 2008... Looking for the same tone and wondering how your amp changes worked out. Also where would you find the Lansing speakers Dickie speaks of? Like to hear what you've learned. Thanks, J R
JohnRussell is offline   Reply With Quote
Old 05-04-2009, 12:46 AM   #8
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
Quote:
Saw that you revived this and thought I would respond. JBL D, E and K series speakers can be found for sale on EBAY. Betts used the E-120's which have enormous ceramic magnets and four of them in a half stack is a boat anchor. The D's and K's had alnico magnets and were much lighter and very close in sound.
Also, I can tell you that Bett's amp didn't have JJ's in it. You can almost guarantee that his guitar tech had a stash of NOS preamp tubes hand selected for his rig and NOS power tubes as well. All this, plus custom work on his amp.
Anyway, I hope this helps.
Marty
Old 11-05-2010, 03:42 AM   #9
Sonicboom
Junior Member
Resurrecting a long dead post in case anyone wants info on this. To clarify, Dickey used D120 speakers, not E120. The E120s were not around until the late 70s or 80s - they, in fact, came after the K-series. Almost everyone back in the day from the Allmans to Grateful Dead to Skynyrd was using D120s.
Today, Dickey does in fact use a Marshall 1987x. I have a close up photo of his amp with the knob settings he uses - it's also posted on his forum. I set my stock 1987x to the same and get his tone. I don't know what tubes he runs, but I've found that with my gear (Winged C EL34s, D120s and WCR Bet Set) I can nail One Way Out from the Filmore. A lot of his tone is in how he holds the pick and where he plays - over the neck pickup.
I've spent a small fortune trying various combinations of NOS power and preamp tubes, thinking maybe he used those back in the day. I can't get the same tone with those tubes. Stick with Winged Cs.
Hope that helps.
Sonicboom is offline   Reply With Quote
Old 11-05-2010, 02:51 PM   #10
thetragichero
Senior Member
thetragichero's Avatar
SLLLAAAAAAAAAASSSSSSHHHHHHHHHHHHHHHHHHH!!!!!!!!!!
__________________
'65 Guild M-65 | BC Rich Special X Mockingbird | Tele Build with Lydian Neck | too many partscasters | Fender Blacktop Jazzmaster | '85 Ibanez RB850 bass | Blacktop PBass partscaster build with JBass neck
'98 JCM 2000 DSL100 | Peavey XXX | Jet City PicoValve | Fender Excelsior | Orange Terror Bass | too many racks!
NOS Tubes, Eminence Speakers
Quote:
Originally Posted by charveldan View Post
I'm happy to pay my tech $40 buck to take the Zap for me.
Quote:
Originally Posted by smcgov View Post
can somone tell my how to drain caps, I got a pretty good jolt last night.
thetragichero is offline   Reply With Quote
Old 11-05-2010, 06:57 PM   #11
telebender1956
Junior Member
Uh, one cannot buy the Tone of Dickey Betts at the guitar shop. His soul and fingers cannot be bought at the music store.
telebender1956 is offline   Reply With Quote
Old 11-05-2010, 09:06 PM   #12
cagamp1
Senior Member
Does anyone know if these WCR pickups sound like '57 classics? Differences? Opinions?
The JBL speakers whether D, E, G, K or M are all higfh quality guitar/musical instrument speakers and have a tone different than your average guitar 12". You can find them on EBAY...not usually cheap.
cagamp1 is offline   Reply With Quote
Old 11-05-2010, 09:37 PM   #13
Sonicboom
Junior Member
Not to me they don't. I have a set of WCRs in my '79 and the '57 classics in my Goldie. The WCRs are more articulate by far.
Gotta agree on the JBLs - awesome speakers, but if they aren't the orig. cone, which many aren't these days, they will not sound the same. They haven't made recone kits for those for years. The only kit you can find is an E-series.
The right gear will get you about 85% of Dickey's tone. The rest, well, Teleblender said it best.
Good luck with your tone search.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
