MarshallForum.com
Reply
Thread Tools Display Modes
Old 08-16-2010, 12:14 PM   #1
ivanss
Junior Member
Connecting the JVM410h
Hi, can anyone tell me how to connect the Marshall JVM 410h head to a 1960 straight cabinet.
The head has 5 inputs and the cabinet has 2 inputs and a switch for mono and stereo.
ivanss is offline   Reply With Quote
Old 08-16-2010, 12:27 PM   #2
LesPaulopolis
Senior Member
LesPaulopolis's Avatar
Re: Connecting the JVM410h
Cab set to mono - use the 16ohm input
head set to 16 ohms / plug into 16 ohm output
__________________
'68 RI LP Custom
'93 Anniversary 6100 (6L6s)
'90 JCM900 4100 (EL-34s)
Epi. Valve Jr. head (Gain & Bright mod)
In Front: MXR Custom Modified OD > Voodoo Labs Sparkle Drive
In Parallel Loop: TU-2 > Flashback Delay > MXR Carbon Copy
LesPaulopolis is offline   Reply With Quote
Old 08-16-2010, 12:50 PM   #3
ivanss
Junior Member
Thanks so much man, but here's the thing, the head has the following inputs (see attached pic also):
Two inputs that say:
1x4 ohm
2x8 ohm
Next to the right other two:
1x8 ohm
2x16 ohm
Next to the right another one
1x16 ohm.
Whis is the one???
Thx so much
Old 08-16-2010, 01:15 PM   #4
Australian
V.I.P. Member
Australian's Avatar
Ivaanss
1.Click the switch on the back of the 1960 cab to the far right.(its now in 16Ω mono)
2.Then plug the speaker cable into the "Right Input" of the 1960 cab.(above this input you'll see "mono 16Ω" written above the input)
3.And then plug the speaker cable into the 1x16Ω input on the JVM.
__________________
Thank You
Marshall Heads
1971-JMP 1959
1977- JMP 1959
1982-JCM800 2203
1989-JCM800 2205
Silver Jub 2550
30th Ann-6100
2007-JVM410
Super JTM/100JH
2008-1959RR
JMD-1
Marshall cabs
1982AJH+1982BJH--White A/GT75's+B/V30's--30th Ann-B-G12T75's
JCM800 A+B/preRolas-- AHW+BHW-- AX+BXClassic/G12M's-- Classic/G12h30's
JCM800 B/G12-65's--1936/V30's --1936/G1265's
Australian is offline   Reply With Quote
Old 08-16-2010, 01:21 PM   #5
spacerocker
Senior Member
spacerocker's Avatar
Strange, I thought 4 x 12 cabs were 8 Ohms....?
spacerocker is offline   Reply With Quote
Old 08-16-2010, 01:37 PM   #6
Australian
V.I.P. Member
Australian's Avatar
The 1960 cabs are 2 x 8Ω(stereo) or 16Ω(mono) or even 4Ω(mono) if switched to the left.
__________________
Thank You
Marshall Heads
1971-JMP 1959
1977- JMP 1959
1982-JCM800 2203
1989-JCM800 2205
Silver Jub 2550
30th Ann-6100
2007-JVM410
Super JTM/100JH
2008-1959RR
JMD-1
Marshall cabs
Old 08-16-2010, 03:04 PM   #7
ivanss
Junior Member
Thx Australian... Got it, now I'm dealing with a lot of signal interference with some of my pedals when I'm in overdrive 1&2 (orange and red, a lot more on red lead).
Looks like my overdrive and distortion pedals are ok, but as soon as my signal goes to the chorus, phase, eq and delays something makes the interference.
Any recomendations???
Old 08-16-2010, 03:11 PM   #8
Australian
V.I.P. Member
Australian's Avatar
I use an "Boss ns2" noise gate. When youre dealing with so much gain, extra pedals will do this. but its easily cleaned up with a noise gate.
If you want a really good noise gate but its more expensive, Ive heard rave reviews about the "ISP GString".
__________________
Thank You
Marshall Heads
1971-JMP 1959
1977- JMP 1959
1982-JCM800 2203
1989-JCM800 2205
Silver Jub 2550
30th Ann-6100
2007-JVM410
Super JTM/100JH
2008-1959RR
JMD-1
Marshall cabs
Old 08-16-2010, 06:07 PM   #9
MonstersOfTheMidway
Senior Member
Send a message via ICQ to MonstersOfTheMidway
When playing through a JVM410H, It's ALL about (a) the number of cabinet you are using (1 or 2 cabs), AND (b)the ohms setting you are using on the cabinet(s)! The JVM features no ohms switching: you just gotta know how many cabinets you are using and the appropriate ohms setting on each. Follow AUSTRALIAN's information and you can't go wrong! Best of luck, Ivan.
MonstersOfTheMidway is offline   Reply With Quote
Old 08-16-2010, 06:48 PM   #10
ivanss
Junior Member
Australian was right man, I've got it all hook up and runnin. But I've just post it another thred regarding another issue. Can you guys help me??? I've install all the tubes myself and notice that the metal cover for one of the preamp tubes has a spring inside. Do I leave it in there with the tube or should I take it out with just the tube en the cover???
Old 08-16-2010, 06:55 PM   #11
Micky
V.I.P. Member
Micky's Avatar
Leave the spring in the cover. It holds the tube down.
__________________
Stupidity should be painful...
Marshall MHZ15, DSL40c, DSL5c, M4, 4X12 full stack, Gibson LP, VOX, Eminence, Celestion, Ovation, Fender & more...
Micky is offline   Reply With Quote
Old 08-16-2010, 06:57 PM   #12
ivanss
Junior Member
It looks like the spring might push down hard on the tube, this won't be a problem???, It won't break it???
Old 08-16-2010, 07:10 PM   #13
Micky
V.I.P. Member
Micky's Avatar
It will be fine.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
