MarshallForum.com
Reply
Thread Tools Display Modes
Old 07-30-2010, 09:21 PM   #1
superdrag81
Junior Member
Marshall Jubilee 2555 - no sound
Hi all
Long time reader first time poster.
I recently had my Marshall Jubilee 2555 amp serviced and got tubes replaced by my local tech. Today when i went to turn it on, i get no sound. I checked all tubes, all lit up - and i even put in the old tubes to make sure nothing was blown.
I only had a spare HT fuse so i tested that and still nothing. I'm still trying to find a place locally that sells 4A 250v fuses for the main fuse.
The weird part is that if i crank the master output past 7 i can start to hear the amp very slightly.
Any advice??
superdrag81 is offline   Reply With Quote
Old 07-31-2010, 02:48 AM   #2
Marshallhead
Senior Member
Re: Marshall Jubilee 2555 - no sound
Put a short lead into the effects send and return sockets and see if it works. These amps are known for the fx sockets to get dry or dirty and cause no sound. It that cures it then you can do a permanent fix if you whip the chassis out and use contact cleaner on the switch connections of the fx loop sockets.
Notes!
Leave the amp alone if you don't know how to work safely inside an amp by discharging the capacitors first
Just using contact cleaner on the sockets from the outside by spraying it on a jack plug will nit normally cure the problem
Marshallhead is offline   Reply With Quote
Old 08-01-2010, 10:10 PM   #3
Sir Don
Senior Member
Sir Don's Avatar
Connect a speaker? Seriously, if you only recently got it back from the tech take it back to him, something seems horribly wrong here.
__________________
My gear:
2204, 2210, 2555, 9005, 1959, 5005,
4103, 2100, JCM1 H, JVM1 C, Class 5,
DSL50, JVM410HJS
https://www.facebook.com/rockintheboss?fref=ts
Sir Don is offline   Reply With Quote
Old 08-02-2010, 11:00 AM   #4
jcmjmp
Senior Member
Quote:
+1. This is a common problem. Try it and get back to us.
jcmjmp is offline   Reply With Quote
Old 01-27-2012, 06:34 PM   #5
Robosoft
Junior Member
I have the same issue and for months i had a cable pluged into the loop.
Now that dosn't fix the problem.
If you put the amp on max you here low sound out of the speakers and the DI
All tubes lit and replacing them with new same issue.
i have shorted the send return internally and same.
could it be the pots on the front and the Gain does nothing??
all caps have 300-500v
Robosoft is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
