MarshallForum.com
Reply
Thread Tools Display Modes
Old 07-14-2010, 03:37 AM   #1
theamericanpsycho
Junior Member
Send a message via AIM to theamericanpsycho Send a message via Yahoo to theamericanpsycho
Lee Jackson Mod
Ok, I own a 1978 Marshall JMP 2204, 50 watt master volume. I wanted a gain increase mod so I took my amp in and I was recommended the "Lee Jackson mod". I waited a while and I stopped in every now and then to ask about the progress and I waited a month to get my amp back. I was told the tech was changing the tubes from stock to el34s and 12AX7s and adding new caps and a few other things I cant remember. Now that I got the amp back home, I fired it up and....it sounds the same. I was thinking I got jipped, so I took the back off....yep, there was certainly new tubes. But I dont hear any gain increase. The guy I went through said I would still need boost pedals (EQ and overdrive) to get the sound I want, so whats the point of the mod? Does anybody know what this Lee Jackson mod is in detail? And why do I hear no difference at all other than a slight marshall growl? I even put the preamp up at 8 and sometimes 10 and thats it, slight little growl. I asked the guy if they did the one wire mod and he looked at me like I had 6 heads. He said he had never heard of it. Any takes on this?
theamericanpsycho is offline   Reply With Quote
Old 07-14-2010, 04:54 AM   #2
Lane Sparber
V.I.P. Member
Lane Sparber's Avatar
Re: Lee Jackson Mod
It sounds like you might need a new tech. I freely admit that I don't know what the "Lee Jackson Mod" is (he has a DVD or two out centered around modding Marshalls, so it could be a conglomeration of things). To that end, could you post pics of the inside of your amp so we can see what might have been modded? Be careful doing this if you're not familiar with high voltage circuits, as these amps contain lethal voltages long after the plug has been removed.
-Lane
__________________
New York Guitar and Amp Tech...and NOT a guru!
WARNING: Tube amps contain LETHAL voltages long after they've been unplugged. If you are not familiar with the safety procedures involved when working on high voltage circuits (such as how to safely drain the filter caps), then PLEASE take it to a tech to stay safe...and alive.
Some of what I do (log in to Facebook): http://www.facebook.com/media/set/?s...4798875&type=3
Lane Sparber is offline   Reply With Quote
Old 07-14-2010, 05:00 AM   #3
PaoloJM
Senior Member
PaoloJM's Avatar
Re: Lee Jackson Mod
Quote:
Originally Posted by Lane Sparber View Post
It sounds like you might need a new tech. Could you post pics of the inside of your amp so we can see what might have been modded?
-Lane
I would say there's no doubt that he needs a new tech...
__________________
www.youtube.com/paolojm
I'm no poindexter, I'm ****ing awesome like this guy
PaoloJM is offline   Reply With Quote
Old 07-14-2010, 07:59 AM   #4
charveldan
Banned
Location: Somewhere with a Friedman Marshall & Les Paul.
Re: Lee Jackson Mod
Wondering why OP would consider a "Jackson mod" from someone other than Jackson himself while still using his name?
charveldan is offline   Reply With Quote
Old 07-14-2010, 07:59 AM   #5
MKB
Senior Member
Re: Lee Jackson Mod
Yup, new tech indeed. I haven't seen the Lee Jackson video, but have worked on a few of his modded amps. Other than a few changed values, the major mods are a selectable midrange "boost" with a six position switch, and an added preamp tube between the tone circuit and the phase inverter. If he installed that mod, you most certainly should have gotten a LOT more gain. But if the total number of tubes in the back of your amp did not increase, he probably didn't do the gain mod.
There is a simple one cap/resistor mod you can do to a 2204 that will increase the gain quite a bit, it's way cheap and reversible. I'd hope he would try that at least.
One other thing; what type of guitar are you using, with what type of pickups? It's possible, if you are using a Strat or other guitar with low output pickups, that you may need more of a gain boost than what you can get from the 2204 circuit arrangement. You may need an added tube or an external boost to get the tone you want.
MKB is offline   Reply With Quote
Old 07-14-2010, 09:21 AM   #6
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
Re: Lee Jackson Mod
Definitely needs a different tech (oh...did someone say that already )?
What kinda sound are you looking to get out of your amp?
__________________
Jon Wilder
http://www.wilderamps.com
Old 07-14-2010, 12:34 PM   #7
Joey Voltage
Senior Member
Joey Voltage's Avatar
Re: Lee Jackson Mod
Quote:
There were many lee jackson mods, some increased gain, and added gain stages, and some were just voicing mods. If you can take a picture of the insides of the amp, and PM them to me, I will tell whether or not he did any of the lee jackson stuff, by the way, how much were you charged fr this mod? That goes for anybody, if anyone has any questions about questionable famous mods, I have inside knowledge about many sought after high priced amps and mods around, and can probably confirm their legitimacy
Joey Voltage is offline   Reply With Quote
Old 07-14-2010, 12:57 PM   #8
surreal amplification
Senior Member
surreal amplification's Avatar
Re: Lee Jackson Mod
You got totally shanked by some ass who bought some videos and thinks he's an amp modder. Even my 15 year old daughter knows what a one wire mod is. The lee jackson mod you wanted adds a tube gain stage after the MV. personally I dont like it.
surreal amplification is offline   Reply With Quote
Old 07-14-2010, 01:03 PM   #9
PaoloJM
Senior Member
PaoloJM's Avatar
Re: Lee Jackson Mod
Quote:
Could never see the point of it. The same amount of gain could be achieved, with equal effort, by putting the gain stage before the CF and keep the tone controls operating. Seems like a mod by someone who doesn't now any better...
__________________
Old 07-14-2010, 01:25 PM   #10
Senior Member
Re: Lee Jackson Mod
Let's see...since the advent of "build it yourself" amp kits how many times has this happened? I can name at least 3 boutique amp shops that are all owned and operated by guys who can build off of a layout but can't hook up a PPIMV to save their life.
Believe it or not I get PMs from a lot of these guys asking how to do simple things that any real tech should be able to look at a simple schematic and figure out for themselves (i.e. PPIMV installs, 6550 mods, etc etc). My whole thought on this is "You call yourself a builder, you run an amp shop, yet you can't even so much as do a simple valve type conversion!?!?"
Then when they get the mods wrong and the customer is less than pleased guess who gets the call to fix all of it, pointless mods and all?
Does it irritate me? Big time. Why? Because it's like these guys want their careers handed to them and think that just because they can build/mod an amp going off a simple layout or because they've worked with some big named "guru" that they're now "instant techs". Yet if asked they couldn't tell you what a choke does, how to wire up a simple relay or an electron from a proton for that matter. Because it's been too loosely thrown around that "Tone is all that matters" when in reality there's a lot more to it than that. Lots of basic electronics theory required to see exactly what's really going on in these circuits.
That being said, I agree it sounds like you got shafted on that mod.
__________________
Jon Wilder
Old 07-14-2010, 01:50 PM   #11
Senior Member
Re: Lee Jackson Mod
Im working on a traynor and the guy said it had a PPIMV. technically this THING in here is after the PI but its a dual 100 k pot.. ?? crossline mv is guess they were referred to as. so that went out.
whats even sadder is people getting looped into a mod simply because the guy doing the mod is a killer player. They get the amp home and say "oh it doesnt sound like yours" Or people charging 500 plus dollars to cascade a preamp on a 1959 or 1987 and lower the filtering.
hey John hows the killer kt88 thing going ?
Old 07-14-2010, 01:53 PM   #12
Senior Member
Re: Lee Jackson Mod
I've got everything but the chassis to build the power amp side of it for testing. Since I'm running two power transformers in it I'm gonna need a little bit wider chassis than a standard Marshall chassis size since I'll be mounting one behind the other. I'm really going OCD on the top mount component layout as I'm considering doing a semi-transparent front on the cabinet so the valves/top components can be seen from the front.
Prolly gonna need a fan or two in the thing as well.
__________________
Jon Wilder
Old 07-14-2010, 02:10 PM   #13
Joey Voltage
Senior Member
Re: Lee Jackson Mod
Thats only one of the many he did, not all of them were like that, and not all of them added an additional stage
Quote:
It's not necessarily for the gain, That particular one does have an effect, that isn't the same as putting the stage in the more traditional place. I wouldn't just jump to the conclusion that Lee didn't know what he was doing. FWIW some of his other Mods do reallocate the added stage in the more traditional spot, just a different way of doing things
Old 07-14-2010, 02:17 PM   #14
Senior Member
Re: Lee Jackson Mod
we know
but the OP wanted more gain....
Old 07-14-2010, 02:19 PM   #15
Joey Voltage
Senior Member
Re: Lee Jackson Mod
This is unfortunately the way of the mod world!, you can either defy, or join them, and hope that the better amp wins (I think we have already has this conversation though). on the flip side, a crappy player will make the best sounding amp sound like an early transistor amp.
Now what REALLY bugs me is the lack of creativity in all of this. It is quite common to see people reverse engineer somebody elses mod, and use it to build their carrers. I find it disgusting
we know
What does wanting more gain have to do with adding gain stages? besides, the OP never said how much of an increase he wanted
Old 07-14-2010, 02:53 PM   #16
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
Re: Lee Jackson Mod
I have several point to discuss. Number one, what do you mean when you say your tech was changing the stock tubes to EL34 and 12AX7? Did you have a 6550 amp? Did you agree to this work? Second, did you discuss the mods with your tech in detail? Did he tell you that you would be getting more gain? Did he tell you that you would be getting more gain without increasing the tube count? I mean why did the tech say that about needing boost and EQ on the amp AFTER THE MOD? I look at it this way. A boost pedal is a mod, if someone is doing a gain mod and you still need a boost, then the mod wasn't worth a damn. If done properly, a modded amp should get really ballsy and crunchy on its own.
Some of the responsibility is on the customers shoulders. They need to establish a rapport with the tech and be on the same page as they are. That way, you know what you are getting.
Personally, I would have researched all of the Lee Jackson mod's before just agreeing to them. I think it is best that the builder has audio clips of his mod's. This may not be 100 percent accurate, but it gives the customer an idea of what the amp will be like.
__________________
Old 07-14-2010, 04:46 PM   #17
Joey Voltage
Senior Member
Re: Lee Jackson Mod
Quote:
He's a famous modder. and they are heard on alot of famous '80's recordings. Dokken under lock and key, Steve vai eat em and smile, Zakk Wylde "No Rest For The Wicked", most Akira Takahashi (Loudness), Paul Gilbert, and Bruce Boullet racer X era, (Paul even used them during mr. big, and some of his solo carrer) the list continues.....
Lee Jackson to the best of my knowledge hasn't done mods in over 20years.
Old 07-14-2010, 10:24 PM   #18
MartyStrat54
V.I.P. Member
Re: Lee Jackson Mod
Oh, I know that the guy has been around. I also know that he has some famous clients. However, I think a A/B of a mod is easier to perceive than an amp being played by Steve Vai in a band scenario.
Also, I started doing Internet searches on him about five years ago and there is quite a few negative comments about him.
Looks like you either like him or hate him.
__________________
Old 07-14-2010, 11:15 PM   #19
Joey Voltage
Senior Member
Re: Lee Jackson Mod
I think had is the more operative word. The only problem with an AB mod comparison is that you would have to be in the same room playing both amps, which makes it all kind of difficult. Sound clips are okay, but even then it's an abstract,and an art in itself! The ultimate, and what I plan to do is record using a good player, a mediocre player, and then terrible one play through it, ehat way you can compare, hell I think I can even get my cat in on it.
Isn't that with anybody though? LOL
Old 07-15-2010, 08:01 AM   #20
MKB
Senior Member
Re: Lee Jackson Mod
Lee Jackson's heyday was back in the early/mid eighties, when the first thing you did when you found an old Marshall was save up an additional $500 so you could ship it off to get it modded. Lee Jackson was the top of the heap back then. Unfortunately back then if you wanted a high gain Marshall tone, you either had to use pedals (with questionable results) or get your Marshall modded. Marshall JCM900's were a response to this trend, giving a Marshall with high gain out of the box.
These days you can get amps with all the gain any sane person would want. I don't understand why people still want to modify their vintage amps, when in many cases they could sell the Marshall for its vintage value, then buy a new amp with tons of gain. Either get a high gain Marshall, or there are many boutique builders that can make you a vintage amp with gain mods. The problem with adding gain to a vintage amp is it radically changes the base tone in most cases, and often hurts or destroys the resale value. So what's the point?
I'd bet many of the famous guitarists with modded amps spent a lot of time with the amp builder, working carefully on the mods until he got exactly what he wanted to fit his guitars and playing style. That's a lot different than just picking a mod out of the air and putting it in your amp without trying it out first. Like Forrest's box of chocolates, you never know what you're going to get.
Old 07-15-2010, 02:46 PM   #21
Joey Voltage
Senior Member
Re: Lee Jackson Mod
Quote:
Originally Posted by MKB View Post
I'd bet many of the famous guitarists with modded amps spent a lot of time with the amp builder, working carefully on the mods until he got exactly what he wanted to fit his guitars and playing style .
I'm a huge advocate of this, and why I love working with local players.
On a side note, back then old marshalls were cheap! like 250 dollars cheap because nobody wanted them, when I was 15 in the mid 90's you could still buy them for $500.00
I agree 1,000,000%
Old 07-15-2010, 03:20 PM   #22
emanlooc
Re: Lee Jackson Mod
I bought my JMP for $500 in 1991. My brother bought a JMP and an 800 for $500 each in 1991, and traded them a year later for an ADA MP-1, Marshall Valvestate 8008 power amp, and a Digitech effects processor. EVEN!! It makes him sick today. I'll confess though, I use the MP-1 and 8008 live today. JMP doesn't leave the studio!
emanlooc is offline   Reply With Quote
Old 07-22-2010, 01:14 AM   #23
theamericanpsycho
Junior Member
Re: Lee Jackson Mod
Thanks for all the input, everyone. I spoke with Jerry from FJAmods and I sent him a picture of my circuit board and he assured me there was NO mod done. There was no added tubes, no mid selector switches, NOTHING. This "tech" did change the tubes from the original 6550s to EL34s which I kind of like, but he is trying to tell me he cascaded the preamp too. Anyone that knows anything about 78 Marshall Master Volumes knows they are already cascaded. He is trying to charge me for a "mod" that the amp already had. And cascading the preamp is NOT a Lee Jackson mod. The guy that set me up with this mod is pissed as hell when he got caught.
The tone I am trying to achieve is the 80s metal tone, think Randy Rhoads tone. And as far as guitars, no cheap POS used in my setup, I am running a Gibson Les Paul Studio through my amp. I am thinking now of just sending the amp off to FJA to have it modded with the Ultimate 80s mod, or maybe just leave it the way it is. It does sound awesome with my MXR Distortion Plus and MXR 10 Band EQ.
Old 07-22-2010, 01:28 AM   #24
theamericanpsycho
Junior Member
Re: Lee Jackson Mod
[IMG]http://img.photobucket.com/albums/v480/1stepin****/GetAttachment1.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v480/1stepin****/GetAttachment2.jpg[/IMG]
Pretty sure there is no mods.
[IMG]http://img.photobucket.com/albums/v480/1stepin****/insidethemarshall.jpg[/IMG]
no added tubes either
Old 07-22-2010, 03:43 AM   #25
Senior Member
Re: Lee Jackson Mod
Apparently you didn't either since you had to ask.
__________________
Jon Wilder
Old 07-22-2010, 03:48 AM   #26
theamericanpsycho
Junior Member
Re: Lee Jackson Mod
Quote:
Nope, but learn something new everyday. I havent had this amp long, my last amp was a Peavy Express 112 that I swear I had about 10 years. Learning more and more everyday. Apparently I know more now than the "tech" working on my amp does
Old 07-22-2010, 03:50 AM   #27
Senior Member
Re: Lee Jackson Mod
Well...when you're ready for a true 80s mod on that 2204 or yours feel free to gimme a call. No valves added.
I'm on the opposite coast from you but rest assured should you decide to send it out here it will come back to you with the tone you're lookin' for.
(707) 584-8827
__________________
Jon Wilder
Old 07-22-2010, 12:16 PM   #28
theamericanpsycho
Junior Member
Re: Lee Jackson Mod
Oh yeah? Well I may do that. Make it sound like the 1959RR and we got a deal.
Old 07-22-2010, 12:51 PM   #29
Senior Member
Re: Lee Jackson Mod
thats an easy mod. Randy still dirty'd it up a bit with some silicon.
Old 07-22-2010, 01:16 PM   #30
theamericanpsycho
Junior Member
Re: Lee Jackson Mod
I was never quite clear what all Randy did to achieve his tone from his amp. I know the Distortion+ and the 10 band played a part in it but there had to be more than just a cascading preamp on a 1959. Thats already practically what I have now in a 50 watt version. And yeah, good luck finding Altecs.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
