MarshallForum.com
Reply
Thread Tools Display Modes
Old 08-22-2006, 07:28 PM   #1
Rock
Junior Member
EVH tone
I want to achieve EVH tone.
What Marshall would you recommend me if I do not want to spend a fortune?
I use a guitar with a Seymour Duncan EVH pickup on the bridge.
Thanks,
Rock.
Rock is offline   Reply With Quote
Old 08-23-2006, 10:20 AM   #2
Hell_Tanner
I achieve a very satisfying brown sound with my JCM800 2203, I bought it used for less than $1170, cab included.
You'll need something like an OD pedal to boost it though (Boss OD-1, SD-1, Ibanez TubeScreamer, Maxon OD-808 and the likes....)
Just depend on how much you really want to spend on an amp.
Hell_Tanner is offline   Reply With Quote
Old 08-23-2006, 03:57 PM   #3
KM1959
Junior Member
What do you consider a "small fortune"? I have a '72 Super Lead and while not cheap, does the EVH thing very well. It does however, require an attenuator (I use a HotPlate) because these things are frighteningly LOUD! No OD pedal is required though. You might want to do a web search though, there are thousands of responses to this question.
KM1959 is offline   Reply With Quote
Old 08-23-2006, 06:31 PM   #4
Guv'nor
Senior Member
Guv'nor's Avatar
Quote:
Originally Posted by KM1959
...You might want to do a web search though, there are thousands of responses to this question.
yeah.... and a lot of **** as what I call "the variac tale"
Guv'nor is offline   Reply With Quote
Old 08-23-2006, 09:22 PM   #5
jerseydrew
Junior Member
My Splawn modded Marshall 1987 head definitely does the VH Brown Sound. Sadly I sold it.
jerseydrew is offline   Reply With Quote
Old 08-31-2006, 05:33 PM   #6
Ralle 500
Junior Member
Here's something maybe worth listening to... My superlead -68... A couple of EVH clips with me playing... I have done several recordings since these clips... but I haven't had the time to put'em up... so far...
BTW... this is my first visit here... looks to be a cool site :wink:
Ralle 500 is offline   Reply With Quote
Old 08-31-2006, 05:51 PM   #7
Guv'nor
Senior Member
Guv'nor's Avatar
Sounds very cool....
Having a look in your site I have found your gear...
One thing is clear...... You're NOT married or she never goes there
Old 08-31-2006, 06:49 PM   #8
Hell_Tanner
I love that guitar!
I've built one that looks a bit like yours, a hidden tribute to EVH of course.
And those samples...WOW!!! Tell us your secret!
Old 09-06-2006, 12:10 AM   #9
superleadfixer
Send a message via MSN to superleadfixer
Re: EVH tone
Thanks,
Rock.
Edward's amp on the first album was a 12series Super Lead (#12301), early 1968 approx., but you'll pay big bucks for an amp like that and its over 35 year old, you could get yourseft the same basic deal with a cloned/replica 1959 amp for much cheaper
__________________
I\'ll mod your SLP (or anyother...) Marshall to REAL plexi specifications/with real replica trannies/etc...
superleadfixer is offline   Reply With Quote
Old 09-06-2006, 09:58 AM   #10
Guv'nor
Senior Member
Guv'nor's Avatar
Re: EVH tone
Quote:
Any suggestion?
Old 09-06-2006, 02:22 PM   #11
wonkka
Junior Member
EVH Tone
Do a search on the other forum, starts with Plexi and ends with Palace. This topic has been a staple there for years with people that have actually seen and disected his amp and his rig. But in short you need: A second hand strat rear loaded with a PAF with a Fender TREM, not a Floyd, into a 67/68 1959 with laydown tranny and some cap changes going into a dummy load...not sure what he used here, a MXR Phase 90, Flange, and EQ, EP3 Echoplex, into several beat Marshall 4x12's with god only knows what speakers, Sunset Sound Studio 1.... I think, Don Landee, and of course Edwards hands, skill and mind. Ralle 500 has nailed it as have others with lesser gear. I think most of it is in the hands.
wonkka is offline   Reply With Quote
Old 09-06-2006, 02:45 PM   #12
superleadfixer
Re: EVH tone
Quote:
Any suggestion?
With the proper transformers, Cerrem (Merren audio) makes the best irons for those years (for 1959), you will need one of his 1.5" Dagnall OT his laydown PT set on 460(B+), the 1968 circuit (12series ones with the caps all inside the chassis except the phase inverter one, affects the flux...) with real Philips caps (Mustard), Sylviana 12ax7WA for the pres, and those big bottle 6CA7 also from Sylviana, RFT 12ax7 is as good IMHO for pres and xf2 (Mullard for the power section also), Ralle uses JJ, so go figure :?
Speakers, a few G12H30 the real ones (55hz and 75hz), a few G12M20 or 25w....that will count for a good 25%+ of the tone...amp is the other 25%, the difference will be in your hand that is a 50% of the tone right there.....
Tom Holmes's PAF copy or a Pearly Gate, EVH from SD is all great...a PAF type P/U...
I could build a 12series type amp with EVH specs in.....
__________________
Old 09-22-2007, 02:57 PM   #13
coldsteal2
Senior Member
coldsteal2's Avatar
Re: EVH tone
Robbin Crosby my old guitarist at the time in 1980 bought four stacks
from him Eddie after a tour (Ps thats a great time to by equipment by the
way! lots of touring bands will totaly sell half thier equipment aftet a tour for
dirt cheep). The amps were Plexis that had been rewired and had oversized
transformers, and added master volume and effects loops in back, some were
metal faces some plexi.
__________________
Playing Marshall's since 1969
Vintage Modern 2266, JCM-800, JCM-900,1960A(G12H's), DSL-401,AVT-50combo , CLASS 5 Head,Orange Rockerverb 50, and cab
My Youtubes......ColdSteal II on Soundclick.com
coldsteal2 is offline   Reply With Quote
Old 09-26-2007, 11:18 PM   #14
clutch71
Senior Member
clutch71's Avatar
Re: EVH tone
What did you do to "remove" Eddie's track? I've been looking for a way to do that for practice.
clutch71 is offline   Reply With Quote
Old 06-06-2008, 11:40 AM   #15
kelly
Junior Member
Re: EVH tone
Coldsteal, did you say Robin Crosby was YOUR old guitarist? Like RAT Robin Crosby?
KD
kelly is offline   Reply With Quote
Old 06-06-2008, 11:51 AM   #16
coldsteal2
Senior Member
coldsteal2's Avatar
Re: EVH tone
Quote:
KD
Yes, check out my myspace photos
played in three bands with him pre Ratt
Robbin in the upper left, im in the upper right, we were roomates
and band mates for three years starting in San Diego then we moved
to LA in 81, right after our last band split he joined up with Mickey Ratt
which later became Ratt
He was the best freind i ever had (RIP Cabber)
__________________
Old 06-06-2008, 11:57 AM   #17
kelly
Junior Member
Re: EVH tone
Right on dude!
Read your bio, You gotta a helluva resume.
Nice!
nice to meet ya!
Kelly
Old 06-06-2008, 12:20 PM   #18
coldsteal2
Senior Member
coldsteal2's Avatar
Re: EVH tone
Just a regular guy
__________________
Old 01-30-2010, 05:56 AM   #19
wkcchampion
Senior Member
wkcchampion's Avatar
Re: EVH tone
I "resurrect" this old thread to share a thought I had yesterday.
A local Rock radio broadcast "runnin' with the devil" while I was coming back home, and I noticed the following.
First I thought it was my car audio system which was either broken or poor quality (hey it's a car radio) or teh broadcast was nto good enough, but going home I checked. I noticed that on the first Van Halen album, the rhythm guitar is almost completely panned on the left. On teh right, there are vocals and solos when present.
I'll do experiments in my DAW, but my sensation is that this influences the sound a lot. By leaving a small part (let's say 10%) on the right channel, an unique phasing effect is created, therefore giving the sound that very particular trebly edge.
Expert audio engineers know that just by changing the stereo image, the sound changes radically.
Let's hear yours.
__________________
Marco
http://pregnosplatter.altervista.org/index.html
The Brown Sound is HERE: http://www.marshallforum.com/cellar/...ally-here.html
Marshall gear :
- JMP-1 midi valve preamp
- 1981 JCM800 1959 SuperLead
- 1983 JCM800 2203
- 1987 Silver Jubilee 2555
- 1969 Basketweave replica with Celestion Pre-Rola G12M 25W T1221
Guitars: 2008 Parker Fly Mojo, 1995 Fly Deluxe "Eldy", 1959 pre-CBS Strat and 1993 ObG 1959 Les Paul replica
wkcchampion is offline   Reply With Quote
Old 01-30-2010, 11:12 AM   #20
ken361
Senior Member
ken361's Avatar
Re: EVH tone
of Ratt? Oh i see yeah you knew him, good guitar player R.I.P
__________________
tone slut
Marshall ŚL40C/Warehouse British Lead Speaker
Gibson Les Paul Traditional Pro II
Fender MIM Strat
Magami cables
ken361 is offline   Reply With Quote
Old 01-30-2010, 11:50 AM   #21
LPMarshall hack
Senior Member
LPMarshall hack's Avatar
Re: EVH tone
Just a regular guy
Just curious...what 900 did you use?
__________________
2500
JMD:1
1960BC
Peavey Vypyr 15
1989 LP Custom
Piece of crap Epi LP-100
Piece of crap Epi Jr.
Everything is a conspiracy
LPMarshall hack is offline   Reply With Quote
Old 01-30-2010, 12:47 PM   #22
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
Re: EVH tone
Let's hear yours.
So does this mean you have to position your amp on one side of the room/stage to get EVH's tone?
__________________
Jon Wilder
http://www.wilderamps.com
Old 01-30-2010, 12:50 PM   #23
wkcchampion
Senior Member
Re: EVH tone
Quote:
I dididn't exepct such a lame answer by you
No, of course it means to mix almost every track of the rhythm guitar on one channel, leaving just a little on the other. It MAY be a contributing factor. I'll do experiments, it's interesting.
__________________
Marco
Marshall gear :
- 1983 JCM800 2203
Old 01-30-2010, 03:29 PM   #24
rjohns1
Senior Member
rjohns1's Avatar
Re: EVH tone
His tone on the album is not a good representation of how his amp sounded. I have several quality bootlegs from 77-78, and his tone is more mellow than the album on those. It sounds just like a plexi turned up. A lot of that album's tone was the magic of Don Landee with some eq's, plate reverb, and several mikes in the room. Edwards tone is overly bright on the album, and he has said in interviews that it was too bright for him, he likes it darker. It' s amazing, the guy who made that famous sound doesn't even like it, yet all of us chase it.
rjohns1 is offline   Reply With Quote
Old 01-30-2010, 03:32 PM   #25
rjohns1
Senior Member
rjohns1's Avatar
Re: EVH tone
The sound on the right channel is a room mic, approximately 10-20 feet away from the amp, with a plate reverb on it. At least that was what Don Landee said it was in some old article I read. but yeah, the sound is made to sound huge with that trick, and it definitely changes it.
Old 01-30-2010, 05:17 PM   #26
wkcchampion
Senior Member
Re: EVH tone
Quote:
Yup there was something I was thinking about. Actually, Landee has the merit for the sound, not Eddie. Eddie is in fact too stupid and knows NOTHING of electronics... see what mess he did to his guitar
I also have to say that I don't like that sound at all, he's too cutting, too dirty and confused. But it's interesting too see how those genius engineers create sounds that make history like this.
Apart from the supposingly Variac'd Plexi, what cabinet did he use? And what mikes? A question that will probably never have the true answer....
I think that Eddie used a standard (nno Variac'd) Plexi live, as high voltage from the Variac may lead the amp to blow in any instant and obviously an amp may run for hours live...
And finally: was the Variac used to run the Plexi at higher or lower voltage? Iv'e read both in different articles. I think that "low" is the answer, starving the tubes delivers more gain... or not? I'll never try it of course....
__________________
Marco
Marshall gear :
- 1983 JCM800 2203
Old 01-31-2010, 12:47 AM   #27
core
Senior Member
core's Avatar
Re: EVH tone
Don't know how much you want to spend but David Bray does amazing amp mods and nails early VH sound. Check out all his clips.
David Bray Amps
__________________
Aces & 8's
core is offline   Reply With Quote
Old 01-31-2010, 05:28 AM   #28
ant_riv
Senior Member
Re: EVH tone
wkchampion, Variacs are a very touchy topic with some people.
re: Use of the Variac. I don't know how Eddie used his Variac, as he has been known to "exaggerate" the truth - liberally sometimes - as to his gear. He used to say he boosted the Variac above 120v. This will make your amp run hotter, and probably with more gain until it catches fire or something worse. If you are lucky, you will just fry your OT and ....
I used a Variac with a 2203 and 2204 plugged into the same one at the same time for about four straight years in the early '80s. I reduced the voltage to just above where the on/off lights would stop working. (The amp would still work when there was not enough voltage to light the lamps.) I had as much crunch as those amps would put out, at manageable volume levels. Also, reduced power tube consumption!
I suspect that if Eddie used a Variac with his amp, this would have been how.
Maybe Jon will chime in on this topic.
ant_riv is offline   Reply With Quote
Old 02-01-2010, 12:05 AM   #29
drolaw
drolaw's Avatar
Re: EVH tone
Check out this guy.
http://www.youtube.com/user/Guitarwa...18/ixQpOyl35VY
__________________
www.irisrocks.com Life's a garden - dig it.
drolaw is offline   Reply With Quote
Old 02-01-2010, 08:22 AM   #30
sahlomonic
Re: EVH tone
Absolutely! That guy has the 2nd best convincing EVH tone with a 5150. Top dog in my opinion goes to vhoholic:
VHoholic
You can grab a 5150 combo for $400 if you're patient enough and scour Craigslist. Bought my 5150 head for $375, bought a XXX for $350, a Carvin Legacy for $250, and my 2203 for $250, all within the last 2 years. No bull****. Be patient and always keep an eye out for deals.
Also . . . a DSL can get very close as well. If you want the ultimate budget brown sound, go buy . . . .
. . . a Crate GFX212. Seriously. Check out JFRocks.com and report back. He does all of his "Vin Heutin" lessons with a solid state Crate amp and it nails it. Convinced me to buy one years before I got my 5150.
sahlomonic is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
