MarshallForum.com
Reply
Thread Tools Display Modes
Old 04-15-2010, 06:36 PM   #1
Webslinger
Senior Member
Replacement foam padding for guitar stands
Does anyone know where I can get replacement padding for my tubular guitar stand? I have one of those nice older ones thats all chrome plated, rather than spray-painted flat black.
The orginal padding looked like tan surgical tubing, and is now all dry-rottted and coming off, but the stand itself is fine and better made than today's stands. I dont need the exact tan stuff, I actually prefer the newer black foam. But I cant find anyplace that sells either type.
BTW-the diameter of the stand tubing is 5/16" so any hose that has an inside diameter of 5/16 should slip right over. (I already tried automobile fuel-line hose, but it looked like crap and I was getting black rubber marks on my guitar)
Webslinger is offline   Reply With Quote
Old 04-15-2010, 07:03 PM   #2
eljeffebrown
Senior Member
eljeffebrown's Avatar
Location: Banding, Snorkeling, High Speed Line Skipping, Boot Hunting, Mud Diving, Midget Pummeling.
Re: Replacement foam padding for guitar stands
Any medical supply house should carry the stuff. It's just surgical tubing.
__________________
Quote:
Originally Posted by MartyStrat54 View Post
Are you loosing your mind???
Quote:
Originally Posted by Blackie View Post
.. I am retarted ...
eljeffebrown is offline   Reply With Quote
Old 04-15-2010, 07:38 PM   #3
Buggs.Crosby
Banned
go to home depot and look for the pipe insulation....it's the same stuff most stands have on it today
like the proline and warwick
Buggs.Crosby is offline   Reply With Quote
Old 04-15-2010, 09:18 PM   #4
MajorNut1967
Senior Member
MajorNut1967's Avatar
I'm with Buggs here, pipe insulation.
Old 04-15-2010, 10:50 PM   #5
dbf909
Senior Member
dbf909's Avatar
+2 on Pipe Insulation at Home Depot or Lowe's. I comes in different diameters and grades of foam. The split type with the peel and stick adhesive is great for stuff like this. I've used it for lots and lots of projects.
dbf909 is offline   Reply With Quote
Old 04-16-2010, 11:00 AM   #6
Webslinger
Senior Member
Thanks guys, but I had considered all those ideas....all to no avail.
The felt padding is not very cusion-ey, and would have to come on a roll that I could wind-around the stand....I've never seen it on a roll.
Window/door weatherstripping was another idea, but that stuff is too soft, and would peel & tear in short time.
Places like Home Depot dont sell pipe insulation small enough. The smallest they have is like 3/4", I need 5/16". I havent tried an actual plubming supply house, but I would'nt even know where one is. (north Jersey)
Same goes for a medical supply place for the surgical tubing, and thats if they'd even sell the public. Surgical tubing is considered "drug paraphenalia", and is also used for slingshots....also illegal in NJ.
There's got to be a way to find out where companies like On-Stage get that black foam tubing? I dont think they manufacture it themselves.
Old 04-16-2010, 01:30 PM   #7
Adwex
Super Moderator
Adwex's Avatar
Be careful, if your guitar has a nitrocellulose finish (Gibsons), some types of rubber will damage it.
Old 04-16-2010, 01:51 PM   #8
VHFreak
I completely agree with Adwex. I used to teach lesson in a music store and I can not tell you how many guitars I saw that came in with messed up finishes from those guitar stands with the surgical rubber padding.Eats right through! I even saw a LesPaul come in that was just a mess because the guy was playing an outdoor gig and sprayed bug spray on himself and the overspray ate the finish. Nasty!!!
__________________
6100LM
1960a Cab 75's
5150 Combo
Ampeg VT-120
Peavey Delta Blues
G&L Climax
1989 Strat Plus w/custom Heckler H/S/S
1997 Gibson LesPaul Standard
Peavey Wolfgang
Ibanez Artcore w/emg 81 & 85
VHFreak is offline   Reply With Quote
Old 04-19-2010, 07:13 PM   #9
MM54
Senior Member
MM54's Avatar
Yeah, watch that. I'm pretty sure that my fingerprints damaged the finish on my guitar
__________________
-Matt
If you don't understand what I'm saying, assume I'm making a joke. Trust me.
Lachesky Amplifiers - Home of the CA10
Orders for 2013 CA10s are now being accepted!
"... And I come from a place
where they drag your hopes through the mud
because their own dreams are all dying"
MM54 is offline   Reply With Quote
Old 04-19-2010, 07:48 PM   #10
Adwex
Super Moderator
Adwex's Avatar
Quote:
Yup, bug spray will eat nitro too. I heard/read a similar story on another forum.
Old 04-19-2010, 07:50 PM   #11
Adwex
Super Moderator
Adwex's Avatar
Quote:
Vinyl too.
I read a story of a guy who had a vinyl strap. He put the guitar in the case with the strap still on. Destroyed the finish.
Old 04-19-2010, 07:55 PM   #12
Adwex
Super Moderator
Adwex's Avatar
I'm with Buggs also on this. I believe that pipe insulation is made of urethane foam, if so, it is quite inert, so it won't react with anything.
Old 04-19-2010, 09:17 PM   #13
thrawn86
Senior Member
That pipe insulation is usually around copper all the time. Copper is very reactive and will change color, etc. if something is messing it up.....that foam never does. I think you're safe there.
The only other thing I'd do is go with some sort of padded velvet-like material, like if I wanted to display my guitars on the wall etc., but not necessary for a stand.
__________________
-Martimus Maximus Tone Packs - MHD Pickups - OFA Pedals-
thrawn86 is offline   Reply With Quote
Old 04-21-2014, 04:45 PM   #14
ColoradoRobert
Junior Member
Unhappy Re: Replacement foam padding for guitar stands
I use very cheap Fret Rest or Pro-line stands and am surprised that Pro-line even says, "use tubing from Home Depot, etc. to replace the foam." WHY? Answer: Probably because they are manufactured in China and they use small wall insulation over there I guess (6.35 mm or 1/4"). * I went to a HVAC parts place, but all they have is thicker wall. Even the 3/8 wall doesn't look right. It should not be this difficult, to find a 6 foot length of 3/8 I.D. foam pipe insulation with 1/4 inch wall... but it definitely is.
ColoradoRobert is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
