MarshallForum.com
Reply
Thread Tools Display Modes
Old 03-28-2010, 08:05 PM   #1
Paramedic006
Senior Member
12AX7 and 12AX7A Whats the difference
What is the A for in the suffix. Can I run both these in my 2204
__________________
Bill Griffith Paramedic/Firefighter/Diver
Current Gear:
Left hand guitars:
2009 Gibson SG Standard
Amp:
1982 JCM 2204
1960A Cab
Marshall MG10
Good transaction members: timgman, beamer23, Joey Voltage(for amp service A+++), RJohns, JCarno, Chuckharmonjr, MM54, Martystrat54, ant_riv
ALL WORK DONE ON MY AMPS BITCHINGLY DONE BY JOEY VOLTAGE--ROCK ON
Paramedic006 is offline   Reply With Quote
Old 03-28-2010, 08:26 PM   #2
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
Re: 12AX7 and 12AX7A Whats the difference
12AX7: the original version of this tube, released in 1947. This can only be used in parallel filament circuits. This is not a big deal as virtually all audio equipment is of a parallel filament design. In other words, these will work fine in a Marshall.
12AX7A: This version can be used in series or parallel filament circuits. These usually date to the 1960s and have gray or black plates. Vintage versions of these are about the most sought after tubes of any type today. Sometimes, 12AX7A tubes made for the US Military are labeled 12AX7WA. DO NOT confuse these with current production Sovtek or Chinese crap with the suffix WX, WB, or WC! These are not military tubes and are not NOS tubes at all.
Also, as tube manufacturing became refined, the 12AX7A became much quieter. So much in fact that a lot of 12AX7A's were labeled 7025's (a very quiet version of the 12AX7).
So the bottom line is that you can use either of these tubes in your Marshall amp. It's just that an NOS 12AX7A tube is considered to be premium over the 12AX7.
__________________
Old 03-28-2010, 08:48 PM   #3
MajorNut1967
Senior Member
MajorNut1967's Avatar
Oh the "A" in 12AX7A stands for Alpha, because the barium they use on the getters is from Alpha Centauri. And it make the tube have a better magnetic flux.
Old 03-28-2010, 09:24 PM   #4
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
When dealing with current production valves, the suffixes in valve numbers don't mean ****. Valve makers/dealers try to use them to denote some difference in gain factor, vacuum hardness, etc etc. Problem is that every company uses them differently and there's no "standard" as to how they're used.
__________________
Jon Wilder
http://www.wilderamps.com
Old 03-28-2010, 09:52 PM   #5
MajorNut1967
Senior Member
Quote:
Originally Posted by Wilder Amplification View Post
The suffixes in valve numbers nowadays don't mean ****. Valve makers/dealers try to use them to denote some difference in gain factor, vacuum hardness, etc etc. Problem is that every company uses them differently and there's no "standard" as to how they're used.
So you would plug a 6L6GT into an amp the requires a 6L6GC? Because "The suffixes in valve numbers nowadays don't mean ****." What's the plate & screen spec for a 6L6GC & 6L6GT are they the same? I think you better retract your statement!
Old 03-28-2010, 09:59 PM   #6
Senior Member
Quote:
Show me datasheets for a current production "GC" and "GT". Not original data sheets from back in the day for valves that aren't being made anymore...datasheets for CURRENT PRODUCTION valves.
Now seeing as how this thread is regarding 12AX7s, my statement is correct. Moreover, the OP is referring to current production stuff.
Now since you're talking NOS 6L6GT (seeing as how no one even makes a current production 6L6GT) you would be correct...the ratings for a 6L6GC are drastically different than an NOS 6L6GT so as such you would not want to plug a 6L6GT into an amp that runs over 330VDC on the plates...but when you deal with NOS stuff you have to know your prefixes simply because the suffixes actually did denote different valve ratings/specs during the golden age of valves. But for current production stuff, the suffixes are all used differently and they're typically used to denote a tonal difference, different gain factor, vacuum hardness, etc etc.
One must keep in mind though that not everyone uses NOS valves. Matter of fact, a very small percentage of people do simply due to the cost factor. This doesn't mean that people feel that CP is better than NOS...this simply means that only a small percentage of guitarists can afford to use NOS. And let's face it....once the supply of NOS runs out, it's over/done/gone and you're stuck with CP valves.
__________________
Jon Wilder
Old 03-28-2010, 10:14 PM   #7
MajorNut1967
Senior Member
Now since you're talking NOS 6L6GT (seeing as how no one even makes a current production 6L6GT) you would be correct...but when you deal with NOS stuff you have to know your prefixes simply because the suffixes actually did denote different valve ratings/specs during the golden age of valves. But for current production stuff, the suffixes are all used differently and they're typically used to denote a tonal difference, different gain factor, vacuum hardness, etc etc.
After all that you still haven't answered my question! Whats that tell us?
Old 03-28-2010, 10:21 PM   #8
Senior Member
Actually....read it again. I DID answer your question...did you not see where I stated -
"Now since you're talking NOS 6L6GT (seeing as how no one even makes a current production 6L6GT) you would be correct...the ratings for a 6L6GC are drastically different than an NOS 6L6GT so as such you would not want to plug a 6L6GT into an amp that runs over 330VDC on the plates...but when you deal with NOS stuff you have to know your prefixes simply because the suffixes actually did denote different valve ratings/specs during the golden age of valves. But for current production stuff, the suffixes are all used differently and they're typically used to denote a tonal difference, different gain factor, vacuum hardness, etc etc."
However...I've just corrected my semantical errors in my original posts so this should be a non-issue.
__________________
Jon Wilder
Old 03-28-2010, 10:41 PM   #9
TwinACStacks
Senior Member
TwinACStacks's Avatar
Jeez and here all this time I thought GT meant Groove Tubes and GC meant Guitar Center....
Here check this out: http://frank.pocnet.net/
TWIN
__________________
Quote:
Originally Posted by triftstrassa View Post
Are you retarted?
Quote: longfxukxnhair
I knew they were wrong. I can find my ass with both hands
Jm D1 Trusted by more musicians than Fed Ex
Want to make GOD laugh? Tell him about your plans.
TwinACStacks is offline   Reply With Quote
Old 03-28-2010, 10:46 PM   #10
Senior Member
Quote:
Here check this out: Frank's electron Tube Data sheets
TWIN
If the GT is a PRE-fix it is.
__________________
Jon Wilder
Old 03-28-2010, 10:52 PM   #11
TwinACStacks
Senior Member
Did You check out that Tube Data Sheet Jon? It's pretty handy for reference.
TWIN
__________________
Are you retarted?
Old 03-29-2010, 01:09 AM   #12
Adwex
Super Moderator
Adwex's Avatar
How 'bout a friendly discussion, instead of a fight.
No need for hostility.
Old 03-29-2010, 03:01 AM   #13
core
Senior Member
core's Avatar
TWIN
Not sure what the GT is but I do know original 6L6 valves had metal canisters and were developed by RCA. When they went to glass tubes instead they added the G to the end of the model number. From what I read on them it seems it's part of a series G, GA, GB, 5881, 5932, 7027, and the final version 6L6GC.
__________________
Aces & 8's
core is offline   Reply With Quote
Old 03-29-2010, 04:01 AM   #14
MajorNut1967
Senior Member
TWIN
LOL great one Twin! Frank's site is one of the best tube data sites there is, nice call.
Old 03-29-2010, 04:05 AM   #15
MajorNut1967
Senior Member
Quote:
Core in the final version (6L6GC) was there quite an increase in Plate & Screen voltage specs? I don't really know the chronology of the 6L6 well. Thanks! I personally think the GT suffix is a more recent marketing of the tube.
Old 03-29-2010, 08:50 AM   #16
Paramedic006
Senior Member
I have a chance to buy 2 12AX7A USA NOS for about 40 bucks, hence my question. Can I run a standard 12AX7 with these 2 other tubes or would it be better to find a 3rd 12AX7A tube. If so, can someone hook me up, RE Martystrat.
__________________
Current Gear:
Left hand guitars:
Amp:
1982 JCM 2204
1960A Cab
Marshall MG10
Old 03-29-2010, 11:15 AM   #17
Paramedic006
Senior Member
Are 2 of these 12AX7A USA tubes worth 35 shipped.
__________________
Current Gear:
Left hand guitars:
Amp:
1982 JCM 2204
1960A Cab
Marshall MG10
Old 03-29-2010, 01:58 PM   #18
Senior Member
Quote:
Yes, and yes. And if you want a 3rd to go with it, Marty can definitely hook you up.
__________________
Jon Wilder
Old 03-29-2010, 02:21 PM   #19
Paramedic006
Senior Member
Thanks Jon. I have no knowledge of NOS tubes and I didn't wanna get them in an uninformed way. I read so much on here about NOS vs CP and I'm gonna start small to see if I can tell the difference.
__________________
Current Gear:
Left hand guitars:
Amp:
1982 JCM 2204
1960A Cab
Marshall MG10
Old 03-29-2010, 03:52 PM   #20
MartyStrat54
V.I.P. Member
If you are buying two 12AX7A's, they will work no problem with a 12AX7.
What brand are they? Do they come with any test results? What brand of tester?
$35 for two isn't bad as that would be in the same price range as two current production Tung-Sol's.
Shoot me a little more info and I can help you out.
__________________
Old 03-29-2010, 04:20 PM   #21
core
Senior Member
core's Avatar
I agree, I would say Groove Tubes added it for their own marketing.
I'm not a tech and I know it's wikipedia so take the info with a grain of salt but it seems to jive with other info I've read up on 6L6's. Still learning here
6L6 - Wikipedia, the free encyclopedia
"...the final version 6L6GC had glass envelopes, which made radiation cooling of the anode easier. The voltage and power rating of the 6L6 series were gradually pushed upwards by adding features such as a micanol base, thicker plates, thicker grid wires, grid cooling fins, and special ultra-black plate coatings. The original metal version was rated for 19 watts dissipation while the later 6L6GC is usually rated for 30 watts."
Cathode
Cathode type: Indirectly heated
Heater voltage: 6.3
Heater current: 900 mA
Anode
Max dissipation Watts: 30
Max voltage: 500
Specification listed is for the type 6L6-GC
Apparently the original metal versions had the shell connected to pin 1 so that's why the glass versions don't have pin 1 connected I assume. No need to right?
__________________
Aces & 8's
Old 03-29-2010, 04:24 PM   #22
MajorNut1967
Senior Member
Cathode
Heater voltage: 6.3
Anode
Max voltage: 500
Thanks Mate, great info! It is much higher spec then the previous versions!
Old 03-29-2010, 04:37 PM   #23
core
Senior Member
core's Avatar
Yes sir!
__________________
Aces & 8's
Old 03-29-2010, 06:48 PM   #24
Paramedic006
Senior Member
I will try to get you some info Marty.
__________________
Current Gear:
Left hand guitars:
Amp:
1982 JCM 2204
1960A Cab
Marshall MG10
Old 03-29-2010, 06:50 PM   #25
Paramedic006
Senior Member
All I know right now is that they say 12AX7A USA
__________________
Current Gear:
Left hand guitars:
Amp:
1982 JCM 2204
1960A Cab
Marshall MG10
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
