MarshallForum.com
Reply
Thread Tools Display Modes
Old 03-28-2010, 04:17 PM   #1
NewReligion
V.I.P. Member
NewReligion's Avatar
When to Change Filter Caps ???
I have read so much about changeing the filter caps on amps since I have become a member here that it prompts the following question.
When looking to buy an older head, or otherwise. How will I know that the filter caps need changed ?
Thanks, David
David C. Hopkins on MySpace Music - Free Streaming MP3s, Pictures & Music Downloads
NewReligion is offline   Reply With Quote
Old 03-28-2010, 04:30 PM   #2
cudamax2343
Senior Member
cudamax2343's Avatar
Re: When to Change Filter Caps ???
Good Question. I'd like to know too.
__________________
Always Running Dirty on 10
cudamax2343 is offline   Reply With Quote
Old 04-04-2010, 10:32 PM   #3
cylon185
Senior Member
bump
__________________
Too much hate on this forum, I have left for a better place.
cylon185 is offline   Reply With Quote
Old 04-04-2010, 10:44 PM   #4
dbf909
Senior Member
dbf909's Avatar
If I buy an amp and the caps are over 20 years old, AND I plan to play the amp - I replace all of the electrolytics. This includes the power supply filter caps, the bias supply filter caps, and the cathode bypass caps. Although there are lots of caps out there made in the 60's and 70's that are working fine, the failure rate is very high. 20-25 years is pretty much where the failure curve goes significantly North...
If an amp has sat in a closet or basement for many years and has not been powered on, the insulator in the caps can dry out and fail. On the other hand, if an amp has been played regularly, the caps will last longer as the warm-up/cool-down cycles actually keep them in good working condition.
This seems counter-intuitive but is true.
A lot of folks just wait and replace them when they go bad. I personally don't want to wait for them to go bad because that will surely happen at the most inopportune moment. And there's nothing worse that seeing smoke pouring out of your amp while it makes a fizzling sound and goes quiet in the middle of a gig.
If we're talking about a "Collector" amp, I would try not to replace them unless they are visibly swollen or leaking. I will power it up slowly on a Variac (over a period of 3-4 hours) and watch them closely to make sure that they are OK.
dbf909 is offline   Reply With Quote
Old 04-05-2010, 02:00 AM   #5
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
10 years is the average life expectancy of filter caps.
__________________
Jon Wilder
http://www.wilderamps.com
Old 04-05-2010, 02:04 AM   #6
cylon185
Senior Member
thx Jon!
Btw, loved the DC 1st part
__________________
Old 04-05-2010, 04:02 AM   #7
PaoloJM
Senior Member
PaoloJM's Avatar
Quote:
Yup, I'd agree, and preventitive maintenance is good guys.
If your amp is coming up to it's 10nth, and you don't fancy weird **** happening during gig, then go ahead and have them replaced, even if the amp is working fine. You don't wait for your tyres to go thread-bare and skid into a ditch do you?
However, I'd just advice people that if your amp gets a bit noisier than normal, is loosing a bit of punch, making stange noises as a note fades out etc. then don't rule out the filter capacitors simply because the amp is "less than 10 years old".
Don't forget that if it looks like a duck, quacks like a duck and waddles like a duck, then it is probably is a duck!!
__________________
www.youtube.com/paolojm
I'm no poindexter, I'm ****ing awesome like this guy
PaoloJM is offline   Reply With Quote
Old 04-05-2010, 05:09 AM   #8
Senior Member
Just to clarify what Paolo is saying regarding the "noisier than normal, loosing punch, making strange noises" statement (only because the way it was worded was way too easy to have it taken literally to the extreme)...this does NOT mean that this is ALWAYS indicative of filter caps. Valves going bad exert those same symptoms. However, if it's a situation where you've got known brand new valves that have been tested in another amp and the amp in question still has the above listed symtoms, then filter caps is another possible cause to consider at that point regardless of their age/actual service life.
Sorry Paolo...just figured I'd "remove the blanket" from the blanket statement.
__________________
Jon Wilder
Old 04-05-2010, 05:52 AM   #9
charveldan
Banned
Location: Somewhere with a Friedman Marshall & Les Paul.
Bias filters are electrolytic as well i always have them replaced too.
charveldan is offline   Reply With Quote
Old 04-05-2010, 09:12 AM   #10
jcmjmp
Senior Member
Filter cap life expectancy varies. Like a lightbulb, an electrolytic capacitor has a finite number of hours in it. Most of the larger can capacitors will last 10'000 hours.
If you used you amp on a regular basis, you can estimate when your filter caps need changing based on the life expectancy of those caps.
The smaller caps, Like in a DSL, will last 5000 to 7000 hours, depending on the model and how it was sized.
For most people, the electrolytic capacitors will last closer to 15 years, maybe more.
There is a method for testing your capacitors but it involves taking them out. If they're already out, you might as well just replace 'em. You can also have a look at the waveforms on an Oscilloscope to get an idea as to how well they're doing their job.
jcmjmp is offline   Reply With Quote
Old 04-05-2010, 09:51 AM   #11
Senior Member
And that brings another interesting trait about practical electronics (as opposed to theoretical electronics) to light...
Everyone wants "guidelines" to follow but at the same time doesn't wanna feel "locked in" to anything. Yet with electronics, two things hold true -
* There are no absolutes
* There are LOTS of exceptions
It is for these two reasons alone that I am against the whole "power valve swapping movement" that seems to have become ever so popular these days. Unless you're well versed in theory and valve amps and really know what you're doing, there's no absolute guarantee that it will work in the short or long term, and there are way too many exceptions that come into play with each amp model and circuit. Even for those of use who ARE well versed in this field there's no 100% guarantee that things will work, but the odds do seem to be in favor of the tech types getting things to work a lot more consistently than those who just simply follow the advice of others. The difference is that when things go wrong, actual techs know where to look whereas the non-techs would be lost up **** creek without a paddle.
__________________
Jon Wilder
Old 04-05-2010, 09:56 AM   #12
jcmjmp
Senior Member
Are you against the "Filter Cap Swapping Movement"? Its the new thing. You ain't cool if you're not doing it.
Old 04-05-2010, 10:08 AM   #13
Senior Member
Quote:
Only if it involves swapping over to the magnetically formed type that use chrome dipped gold irradiated titanum foil plates with the space age cryogenic radiation treated dielectric. Only then will I ever buy into that.
__________________
Jon Wilder
Old 04-05-2010, 10:09 AM   #14
anthonyr
Senior Member
anthonyr's Avatar
Can you still get brand new Daly or LCR caps for guys who want the original look? Or can someone suggest a comparable brand X for a standard 50 50 500?
anthonyr is offline   Reply With Quote
Old 04-05-2010, 10:13 AM   #15
Senior Member
Quote:
I'd use F&T. They look very much like the LCR 50x50s but are a little bit shorter.
NOS filter caps are a moot point. Just like batteries, they have a shelf life and as such they're a crapshoot and there's no guarantee that they'll be any good.
Unless you have a way to test/measure them prior to installing them it's never a good idea to use caps that are decades old even if they've been sitting in a box all their life.
__________________
Jon Wilder
Old 04-05-2010, 10:25 AM   #16
anthonyr
Senior Member
anthonyr's Avatar
That makes sense to me. If we're replacing "old" caps, why replace them with "old" caps? Particularly ones that have been sitting unused, as I understand the dielectric goo dries out from non use. Anyway, thanks for the tip. I actually hate this topic because it starts me thinking that I should replace mine based on age alone. The performance isn't an issue but if it has faded over 28 years, you wouldn't know what you've been missing until you popped some new ones in.
Old 04-05-2010, 11:14 AM   #17
PaoloJM
Senior Member
PaoloJM's Avatar
Where can you buy those? I can usually only get standard TAD or F&Ts.
No worries on the blanket clarification. I was just trying get to the people that say "my amp is only 5 years old, it can't be the caps". I've seen it mentioned here once or twice here.
It does kinda seem like vintage collectors, weekend Dumble stock exchange guys, wanna-be internet gurus and people that listen to amps with their eyes and internet forums, have removed a lot of the science from amplifier electronics.
Can you imagine if NASA or Formula 1 worked like that?
__________________
Old 04-05-2010, 04:57 PM   #18
NewReligion
V.I.P. Member
Thank you all for the input and data as it pertains to Caps. From this information I will be better prepared to make sound purchasing decisions. Thanks again.
David
Old 04-20-2010, 10:15 PM   #19
LPMarshall hack
Senior Member
LPMarshall hack's Avatar
How much can one expect to pay to replace caps?
__________________
2500
JMD:1
1960BC
Peavey Vypyr 15
1989 LP Custom
Piece of crap Epi LP-100
Piece of crap Epi Jr.
Everything is a conspiracy
LPMarshall hack is offline   Reply With Quote
Old 04-20-2010, 10:26 PM   #20
MM54
Senior Member
MM54's Avatar
I don't know how much a tech would charge to do it, but for just the filter caps themselves, a good estimate (in my experience) is $10/each (really like $8 or $9, but this way you don't have to add shipping).
__________________
-Matt
If you don't understand what I'm saying, assume I'm making a joke. Trust me.
Lachesky Amplifiers - Home of the CA10
Orders for 2013 CA10s are now being accepted!
"... And I come from a place
where they drag your hopes through the mud
because their own dreams are all dying"
MM54 is offline   Reply With Quote
Old 04-30-2010, 02:59 PM   #21
Lane Sparber
V.I.P. Member
Lane Sparber's Avatar
Just for fun (and because I didn't know where else to put this), I just recapped my own personal Jubilee 2558 combo (and also fixed the heater wiring and the grid resistor leads on the power tubes), and when I was done, I decided to cut open one of the old filter caps to see how they were constructed. I've been curious about this for a while, and it got the better of me, I guess. So here's the inside of a Ruby "GoldCap" 50uf/50uf @500v cap from 2005. Notice how it is NOT two separate caps, but one massive dielectric with taps on it to create the two 50uf sections. Nothing revolutionary or vital here, but pretty neat to see it nonetheless, no?
-Lane
Lane Sparber is offline   Reply With Quote
Old 04-30-2010, 04:35 PM   #22
MM54
Senior Member
MM54's Avatar
Very cool, I always kind of wondered about what was in these
__________________
-Matt
Old 04-30-2010, 05:19 PM   #23
core
Senior Member
core's Avatar
Cool! You ever see that new show called "Sliced"? It does exactly that but on a big scale. Say take a sawsall to a pinball machine or slot machine or whatever and take a look at how it works. Reminds me of that!
__________________
Aces & 8's
core is offline   Reply With Quote
Old 04-30-2010, 06:04 PM   #24
Lane Sparber
V.I.P. Member
I may or may not be guilty of doing this on larger objects myself as well...especially my parents' things when I was a kid! :-) That's how you learn how things work, right? Also...Core...thanks for the heads up! I HAVE to look that show up now!
Old 05-02-2010, 01:13 AM   #25
Jesstaa
Senior Member
Jesstaa's Avatar
Send a message via MSN to Jesstaa
I guess I get rid of my caps. My amp is 15 and has the original caps, and I've noticed a bit of noise/buzz recently.
And sometimes it has a lot of punch, but others it's a little weak.
__________________
GEAR LIST
Amps
1983 JCM 800 2203
1960AX
Guitars
B.C Rich Bich Perfect 10
Jackson Kelly
Basses
Ibanez SR300
Stagg BC300
I'm not a tech, don't take my advice as fact, I just like to offer my views.
Jesstaa is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
