MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 05-04-2008, 01:39 PM   #1
abbiehuxley
Junior Member
Wiring 4 8ohm speakers at 16 ohms
Is it possible to take 4, 200 watt EVM 12L's (which are all rated at 8ohms) and wire them in a 4x12 cab so that the total load is 16 ohms? Any info much appreciated...
abbiehuxley is offline   Reply With Quote
Old 05-04-2008, 02:53 PM   #2
Adwex
Super Moderator
Adwex's Avatar
Re: Wiring 4 8ohm speakers at 16 ohms
Quote:
No way, no how.
Choices are:
all 4 in parallel = 2 ohms
series/parallel pairs = 8 ohms
all 4 in series = 32 ohms
3 in parallel, in series with the 4th = 10.66 ohms
3 in series, in parallel with the 4th = 6 ohms
To get 16, you'll have to either add speakers, remove speakers, or get 4 16 ohm speakers.
Another option is to get a HotPlate and use it as a dummy speaker load in series with your 8 ohm cab, but you'd be better off just getting more, or less, or different speakers.
Old 05-05-2008, 10:18 AM   #3
ZoomZilla
Senior Member
Why do you want to increase the ohms?
ZoomZilla is offline   Reply With Quote
Old 05-05-2008, 04:00 PM   #4
abbiehuxley
Junior Member
I just think amps sound better running at 16 ohms so I was hoping I could find a way to run the cab at 16 ohms. Guess not...
Old 05-05-2008, 04:30 PM   #5
ZoomZilla
Senior Member
I guess we are the opposite. I rewired mine FROM 16 to 4 Ohms. I think the lower resistance allows more power into the speaker so it sounded better to me.
Old 05-05-2008, 04:37 PM   #6
Adwex
Super Moderator
Adwex's Avatar
A long time ago, I tried comparing running at 4 and 16 to see any difference. I didn't hear any. It's certainly not worth doing what you would have to do.
Old 05-05-2008, 04:58 PM   #7
ZoomZilla
Senior Member
I may change mine back to see if the difference I heard was due to speaker wire upgrade, or ohm droppage. It's not like it's difficult to do! I just have to desolder all of my connections, but once the iron is hot, that takes a few seconds per connection.
Old 05-05-2008, 05:01 PM   #8
abbiehuxley
Junior Member
Ok... so a 4x12 cabinet with 4, 8ohm EVM 12L's would have to be in series/parallel pairs to run at 8 ohms? Man, I'm terrible at this... Thanks!
Old 05-05-2008, 05:06 PM   #9
Adwex
Super Moderator
Adwex's Avatar
Correct.
Just checking....Do you know what "series/parallel pairs" means?
Old 05-05-2008, 05:16 PM   #10
ZoomZilla
Senior Member
Yes, it would have to be in series/parallel. What that basically means is that your left and right set of speakers are wired together in parallel. That means that if you have 8 ohms speakers, the left and right speakers are wired to 4 ohms, then the two sides are joined (series) and you add up both sides to get the total. So your 8 ohms comes from wiring up 2 SETS of speakers wired to 4 ohms. In other words, you could get a jack plate for the back and do a ton of different configurations. You could have a 2 ohm in put, a 8 ohm input and 2 stereo 4 ohm inputs, however hardly any amps have 2 ohm outputs, so that would make that input worthless. But you could use the others!
Old 05-06-2008, 01:22 AM   #11
5er driver
Senior Member
5er driver's Avatar
Speaker Impedance Calculator here:===> Speaker impedance
__________________
The 5er Driver's Home Jams
Do You Really Think So
So I'm No Knight
**** (You Have Me Wondering)
Hellbent
Coke and Joe
Maybe It Will Be
Happy For Some Reason
On My Way
Nice to Meet You (Again)
Now Annoying In
((((((Stereo))))))
Plug that beotch in an' let her rip!
5er driver is offline   Reply With Quote
Old 05-18-2009, 01:02 PM   #12
Crookshanks
Junior Member
Need a the definite ramifications. 50 watt tube wired into two 8 ohm Celestions in a parallel circuit bringing it down to 4 ohms per speaker and 25 watts per speaker. Good or bad? Then single speaker MG50DFX 8 ohms connected to the two eight ohm speakers. Adviseable?
Crookshanks is offline   Reply With Quote
Old 10-21-2015, 12:50 AM   #13
Slimjim
Junior Member
Slimjim's Avatar
here is a video on how to do it, so i guess it can be done..
I have a cab with 4 - 8 ohm speakers run in parallel / series, and for some reason the output jack is reading 13 ohms.. go figure.
https://www.youtube.com/watch?v=kQ6_uYAb_CM
This is how mine is wired up.
Slimjim is offline   Reply With Quote
Old 10-21-2015, 07:37 AM   #14
ampmadscientist
Senior Member
ampmadscientist's Avatar
Location: Sits up in a tree, learning how to play the flute.
Quote:
No it does not allow more power, but it might sound differently.
16 ohm speaker, amp set 16...
is same exact power as
4 ohm speaker, amp set on 4 ohms.
no power increase.
4X EVM wired 8 ohms, amp set 8 ohms, will be just fine.
again, the same power as
16 ohm speaker, amp set 16 ohms.
EVM speaker sounds quite nice! My favorite speakers.
__________________
ampmadscientist is offline   Reply With Quote
Old 10-21-2015, 08:19 AM   #15
Georgiatec
V.I.P. Member
Georgiatec's Avatar
13-14 would be a normal reading for four 16 ohm speakers wired series / parallel...my guess would be your speakers are 16 ohms. Disconnect one and check across the terminals.
__________________
JCM2000 DSL100
VINTAGE MODERN 2466 WITH 425 A & B CABS
2061x
SL-5, CLASS 5 Mk 1.
JMP1c & JCM1H.....BADCAT UNLEASH
JMD50
1960B, MX212, 1922 & VS112 CABS
1983 FENDER TWIN REVERB II
1978 PEAVEY CLASSIC 212 COMBO
GIBSON LES PAULS....R7, R8, R9, R0, '04 CLASSIC & '12 TRAD. PREMIUM
'00 FENDER USA STANDARD TELECASTER
FENDER MODERN PLAYER TELE+
'94 FENDER MIJ '62 RI FOTOFLAME STRAT.
'99 FENDER USA STANDARD STRATOCASTER
Georgiatec is offline   Reply With Quote
Old 10-21-2015, 10:10 AM   #16
chuckharmonjr
Senior Member
chuckharmonjr's Avatar
Location: About as far south in Alabama as you can go without swimming
I concur completely with Tony....gotta be 16 ohm speakers...Ohm's law don't lie
__________________
JCM2000 DSL100
JMD-1 100 Watter
JMP800 2204
Hughes and Kettner 18w
JTM 50
1960A
1960B
2061BX Clone
(2)Seismic Audio 2-12
Avatar V30 1x12
Joe B Sig Goldtop
Tobacco Burst Les Paul
Black Les Paul Custom
Honey Burst Les Paul
R8 Les Paul in Tea Burst
ES-175 in Cherry
EDS-1275 in White
Fender Strat in Tobacco Burst
http://soundcloud.com/chuck-harmon-1/woman
http://soundcloud.com/chuck-harmon-1/webs-and-dust
chuckharmonjr is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
