MarshallForum.com
Reply
Thread Tools Display Modes
Old 09-16-2006, 06:54 PM   #1
Guv'nor
Senior Member
Guv'nor's Avatar
The MarshallForum Guide to Marshall Amps
THE MARSHALLFORUM GUIDE TO MARSHALL AMPS
This is just some information about the main BIG Marshall tube amps. It is not a definitive guide or something like that. Just some points to help to understand the different models, what they do, and who uses them.
There are some other important models (18w, JCM600, newer models…) and there were also Bass/Super Bass versions of the 50w/100w amps. Then PAs… but below are the real BIG Marshalls.
Marshall has done different RIs in recent years (as you may know).
JTM45 / Bluesbreaker combo
- Introduction: 1962
- Models 1987, 1961 (BB with 4x10”) & 1962 (BB with 2x12”)
- Tubes: 2x5881 & 3xECC83
- Used 6L6GT whenever supplies of the 5881 dried up
- From Jan/64 to Dec/65 due to a problem of supply with the American tubes Marshall used KT66 being the tone more crunchy. Let’s say more “Marshall”
- The front panel reads JTM50 (Jim and Terry Marshall – Terry is Jim’s son)
PLEXI PANEL
- Introduction: 1966
- Models 1987 (50w) and 1959 (100w)
- Power tubes change from KT66 to EL34
- Character: Tighter, louder and fuller distortion
- Hendrix, EVH, ACDC etc…
METAL FACE
- Introduction: 1969
- Change from Plexiglas to gold aluminium (front and back panels)
- Circuits remain PTP (and therefore the same as plexi models) until 1974
- Character: From 1974 (printed circuit board) brighter, more aggresive and less harmornics.
- The front panel reads JMP (Jim Marshall products)
- 70s classic rock
MASTER VOLUME
- Introduction: 1975
- Marshall included a preamp gain control
- Character: Bright and punchy. Real screamers
- Iron Maiden, Judas Priest (old), Black Sabbath…
JCM800
- Introduction: 1981
- 1 channel model: Just cosmetics changes
- 2 channels model: Channel switching, reverb and effect loop
- Character:
+ 1 channel: same as master volume
+ 2 channels: More gain and more aggressive than the single channel version
- Zakk Wylde, Motley Crue, Tom Morello…
Silver Jubilee
- Introduction: 1987 celebrating 50 years in music and 25 years in amp industry
- Pentode / Triode switch
- Gain mode switch
- Character: Dark and more gain than a JCM800
- Slash
JCM900
- Introduction: 1990
- 1 channel model (Hi gain master volume)
+ 1990: 2500 (50w) and 2100 (100w) – More gain (up to 20) and dual master volume
+ 1993: 2500SL-X and 2100 SL-X – Extra ECC83 (more gain)
- 2 channel model (Hi gain dual reverb) – 4500 (25 or 50w) and 4100 (50 or 100w): Channel switching and dual reverb
- Character: grungy & more metal tone
- Dave Navarro, Pete Friesen, Jane’s addiction…
30th ANNIVERSARY
- 6100LE: Brass-plated chassis. Limited to 800 units worldwide
- 6100: EL34 tubes
- 6100LM: 5881 tubes
- 4 x EL34/5881 and 7 x ECC83 = 11 valves!!!!
- 3 channels – Tried to produce the tones of all great Marshall amps
+ 1: Clean (JTM45)
+ 2: Crunch – 3 positions: Superlead / Master volume / JCM900
+ 3: Gain – 2 positions: Super gain / Super Ultra gain
- 4 way output power switching: You can select Pentode or Triode & 2 or 4 output valves meaning 25w, 50w or 100w depending on your selection.
- Serial / Parallel effect loop with trim controls on each channel
- Balanced compensated output
- Speaker emulator
- Output valve protection circuitry
- Character: Every character?
- Joe Satriani, Johhny A.
Hope it helps. Sorry if I left something you consider important.
Guv'nor is offline   Reply With Quote
Old 09-19-2006, 01:07 AM   #2
sickboy79
sickboy79's Avatar
Great informative post!
sickboy79 is offline   Reply With Quote
Old 10-13-2006, 03:12 PM   #3
swankmotee
Great job except for one, small error....
Marshall changed from PTP to PCB in 73'.
My compliments on the great site and to all the efforts getting it done!!!
__________________
Old Strats & Vintage Marshall\'s!
swankmotee is offline   Reply With Quote
Old 10-14-2006, 10:43 AM   #4
Guv'nor
Senior Member
Guv'nor's Avatar
Thanks for the compliments. You're the ones making this happen with your contributions and comments.
I didn't find when exactly happened but most of the 1973 amps were PTP so I stablished the change in 1974 when all amps became PCB even it is not exact.
Old 07-08-2007, 02:08 PM   #5
ripper
Junior Member
ripper's Avatar
re: The MarshallForum Guide to Marshall Amps
Been a while since anyone acknowledged that post, eh?!
So, thanks! Great post, learnt a lot about the Marshall series. The 30th anniversary models seem worth drooling over.
ripper is offline   Reply With Quote
Old 09-22-2007, 12:19 PM   #6
coldsteal2
Senior Member
coldsteal2's Avatar
Thats a great list thanks
__________________
Playing Marshall's since 1969
Vintage Modern 2266, JCM-800, JCM-900,1960A(G12H's), DSL-401,AVT-50combo , CLASS 5 Head,Orange Rockerverb 50, and cab
My Youtubes......ColdSteal II on Soundclick.com
coldsteal2 is offline   Reply With Quote
Old 12-20-2007, 09:00 PM   #7
BMD2
Junior Member
TSL 100 bias problem. I checked by bias with a volt meter and the right side was high. I brought it back down and got them both at 90 mv and turned the amp off. 10 minutes later when I turned the amp on (and let it warm up on stand by first and then on and stabilize a few minutes) the right side was low. Amp was making a slight clicking sound through the speakers. Does anyone know any reason why this is happening?
BMD2 is offline   Reply With Quote
Old 01-15-2008, 09:46 PM   #8
Tumbling Dice
Junior Member
Tumbling Dice's Avatar
Great list. Very helpful. Where do the DSL, TSL, and JVM fit into this list of great Marshall amps in terms of their "character"? In other words is the DSL supposed to sound like a JCM 800, the TSL more like a JCM 900? JVM both 800 and 900?
Tumbling Dice is offline   Reply With Quote
Old 01-22-2008, 02:05 AM   #9
JMnovice
Junior Member
Thumbs up re: The MarshallForum Guide to Marshall Amps
Guv'nor,
As you can see by my user name, I am new to Marshall amps. That being said, I just wanted to give you a BIG THANKS for your information. I have been trying for two hours to determine what kind of Marshall will provide the sound I need. Thanks to you, I know what to set my sights on..thanks again!
JMnovice
JMnovice is offline   Reply With Quote
Old 02-07-2008, 10:44 AM   #10
JonnyGator
Junior Member
Just what I've been looking for since I bought my second Marshall...Thanks a million!
JonnyGator is offline   Reply With Quote
Old 02-07-2008, 06:50 PM   #11
JonnyGator
Junior Member
Cool re: The MarshallForum Guide to Marshall Amps
Sorry, I'm new to this establishment and don't know my way around yet, but can someone tell me where 'The Amp Room' is? I can't find it on the forums list, and there is a cab for sale by peedenmark7 I wanted to ask a question about....Thanks....
Old 03-24-2008, 12:23 PM   #12
JASON_NORTH_BLUES_BAND
JASON_NORTH_BLUES_BAND's Avatar
Good article! Even I learned something and I have owned and still do own a variety of models from different eras from 60's to 90's. Well done and keep listening to rock and the blues!
PS my band is on youtube and myspace,
Jason North Blues Band
JASON_NORTH_BLUES_BAND is offline   Reply With Quote
Old 05-06-2008, 12:15 AM   #13
357mag
Senior Member
It would be nice to see a little about the solid state MG series or the AVT Valvestate series. Tube amps are not without problems, believe me.
357mag is offline   Reply With Quote
Old 05-08-2008, 03:43 PM   #14
steelhorse
Senior Member
steelhorse's Avatar
Thanks for the great info!
steelhorse is offline   Reply With Quote
Old 06-21-2008, 08:03 AM   #15
plexipaul
Senior Member
plexipaul's Avatar
Some additional info i`ve found..
the MKII list:
Models in the MK II 100 watt series include:
2959 head (reverb and boost, no master volume) circa 1978-1980
2203 head (1 channel, master volume) 1975-1981
2159 2x12 combo ("4 pronger", twin channel - combo version of 1959 head) 1977-1981
2103 2x12 combo (single channel, master volume - combo version of 2203) 1975-81
2068 head (4 inputs, 2 channels, reverb "Artist" model) 1971-1978
1992 head (4 inputs, twin channel. "Super Bass". Also available with Trem up to 1972) 1966-1981
1968 head (8 inputs, 4 channels. "Super PA") 1966-1975
1959SLP head (4 inputs, 2 channels. Reissue of 60's plexi.) 1993-present
1959X head (4 inputs, 2 channels. First of the plexi reissues.) 1991-1993
1959S head (4 inputs, 2 channels. First Marshall reissue.) 1988
1959 head (4 inputs, 2 channels. "Super Lead". Tremolo model T1959 discontinued early 1970's.) 1966-1981
The 1959 model is refering to the schematics of the amp and you can find them all the way till early 80's and they are all Super Leads. They all have vertical inputs 2 channels/4inputs (JCM 800 1959 that's from 1981). Now what year is as real Plexi or not/metal panel bla bla bla you covered it right......
1959: 1966-1981 (the real ones boys and girls)
1959S: was in 1988 Marshall first reissue
1959X: from 1991-93 first reissue of the sixties plexi 1959
1959SLP: from 1993 Most accurate of sixties Plexi reissues
JTM 45 are not 1959 model nor Super Leads except for the 100watt because they used the JTM45's panel so there is some JTM45 (100watts) that are 1959's but that was in 1966 when Marshall made the switch to 100watt's amp to later made the 1959.
JTM45 are normally 45watts some 50watts and the very first ones, the MK1's or prototype apparently (1962-64) didn't even have a model number then it became the 1987 MKII (the lead version, high treble and normal channels....1965-66), there were the Bass version the 1986 JTM45 from 1965-66, they even had the T1987 for tremolo version same years
Now the JTM45 reissue is the "JTM 45" and started in 1989, it's the reissue of the old JTM45 1987model of 1965-66
And they had PA and organ JTM 45's also but that is an other story
plexipaul is offline   Reply With Quote
Old 07-11-2008, 07:10 PM   #16
aussiebluesville
Senior Member
aussiebluesville's Avatar
hey,thanks for everyone's input on this thread,you have some really informative information on some of the great marshall rigs on offer,cheers
__________________
Jcm 800 1 x 12 Valve combo 4010.
KLD GT20HM Head
1x12 cabinet eminence tonespotter speaker.
2012 Epiphone Dot Studio(seymour duncan SH1&SH4)
Fender 2011 USA Telecaster.
www.myspace.com/ourcreationsjamband
www.soundclick.com/ourcreationsjamband
aussiebluesville is offline   Reply With Quote
Old 07-12-2008, 05:21 PM   #17
cooletv
Junior Member
Thanks to everyone for the info! Just one question remains for me...I'm torn between the Silver Jubilee and the 6100. Can the 6100 acheive a Jubilee tone?
cooletv is offline   Reply With Quote
Old 07-20-2008, 01:48 PM   #18
coldsteal2
Senior Member
coldsteal2's Avatar
I never compared them side by side, maybe there is a Youtube of it
__________________
Old 09-11-2008, 12:32 PM   #19
obagaba
Junior Member
Send a message via Yahoo to obagaba
I have been Using Marshall for many years and this is the first time I have ever had a proublem. I recently purchased a 2266 combo and i cant get the crunch that I have been used too. Can any one help me? I've been told Get a power Brake, but with the money that i spent for the amp, it should have all I need.
obagaba is offline   Reply With Quote
Old 10-10-2008, 01:18 AM   #20
ampshoping123
ampshoping123's Avatar
top info thanks
ampshoping123 is offline   Reply With Quote
Old 10-10-2008, 03:34 AM   #21
steelhorse
Senior Member
steelhorse's Avatar
Quote:
Do you know when the tubes were last replaced?
__________________
www.ricojronline.com
760-956-6619
Garmopat Pedal Mods
I wouldn't mind hearing your head smash through a glass door. That would be cool..." luekmeyer
Old 10-13-2008, 01:33 AM   #22
Pie
Junior Member
Send a message via MSN to Pie
Would it be possible to append suggestions to the original post, assuming later posts are written in teh same format (to keep e verything readable ) ?
Pie is offline   Reply With Quote
Old 10-19-2008, 08:14 PM   #23
ashleypier
Junior Member
This is all great info. thanks!!
ashleypier is offline   Reply With Quote
Old 11-02-2008, 09:49 AM   #24
crunchdaddy
crunchdaddy's Avatar
Nice job on your post of the main BIG Marshalls!
crunchdaddy is offline   Reply With Quote
Old 11-14-2008, 08:45 PM   #25
wareagle
Senior Member
wait so a 1978 jmp isnt plexi?
wareagle is offline   Reply With Quote
Old 11-16-2008, 01:57 PM   #26
crunchdaddy
No...Awesome amp though! They quit making Plexi's in 1969. There are the re-issues but I don't think that there were any in 1978. You may have the amp that is described well in Michael Doyle's "History of Marshall" book from about pages 30 to 40 (photo page 37) as the Bold New Look amps...probably a 2203 100 watt master volume.
Old 11-18-2008, 08:39 AM   #27
janarn
Senior Member
janarn's Avatar
Most Plexis had JMP fronts. The 50w models had JMP fronts from mid '67 to mid '69. I think the 100w converted even earlier.
janarn is offline   Reply With Quote
Old 01-03-2009, 01:45 AM   #28
backline
Junior Member
backline's Avatar
Very nice.
My Marshall experience is limited (and confused). This really helps!
backline is offline   Reply With Quote
Old 01-18-2009, 08:06 PM   #29
lucky find
Junior Member
Hi, Perhaps you could tell me about an amp I found while clearing out my attic.
It's a 1974 Super PA unmodified according to Marshall and I don't know where it would be best to sell it and how much to ask for it. Any advice would be greatly appreciated. Cheers!
lucky find is offline   Reply With Quote
Old 01-20-2009, 10:41 AM   #30
brett octane
Nice, I always wondered what the jtm stood for lol...go figure..:0
brett octane is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
