MarshallForum.com
Reply
Thread Tools Display Modes
Old 12-18-2009, 02:59 PM   #1
LPMarshall hack
Senior Member
LPMarshall hack's Avatar
Cascading preamp stages
When they talk about some JMP's as having the "cascading preamp stage", what does that mean? Is a "cascading preamp" desireable? What is the difference between that and a non-cascading preamp? Thanks in advance.
LPMarshall hack is offline   Reply With Quote
Old 12-18-2009, 08:50 PM   #2
LPMarshall hack
Senior Member
Re: Cascading preamp stages
Anyone home? Hello...?
Old 12-19-2009, 06:04 AM   #3
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
Quote:
The same difference between a Super Lead and a Master Volume (i.e 1959/1987 and a 2203/2204).
__________________
Jon Wilder
http://www.wilderamps.com
Old 12-19-2009, 04:15 PM   #4
LPMarshall hack
Senior Member
Quote:
Still not clear. I know to get a SL to distort, you must crank it, where a MV can distort at lower volumes. Does a cascading pre amp stage have something to do with this? I'm still not sure what a cascading pre amp stage is and if it is more desireable. Sorry for being so dense.
Old 12-19-2009, 04:44 PM   #5
Senior Member
Yes.
"Cascading" refers to the fact that all of the gain stage outputs run into the next gain stage, like a "daisy chain", or like how you hook your pedals up (out from one and into the next). The 2203/04 is set up in this fashion.
This is as opposed to "mixing" gain stages, where the outputs of the first two gain stages are 'mixed' via joining the outputs of the two stages together via a couple of resistors. The 1959/87 circuit is set up in this fashion.
__________________
Jon Wilder
Old 12-19-2009, 06:14 PM   #6
LPMarshall hack
Senior Member
Yes.
Oh I see, so that's what the patch cables are for on a SL...to mix the gain stages? So most modern amps will have a cascading gain stage then right?
Old 12-19-2009, 06:15 PM   #7
Senior Member
Yep...and yep. The patch cable on the SL is just to be able to send your guitar signal to both of the first gain stages vice one or the other. The outputs of those stages are then mixed together.
__________________
Jon Wilder
Old 12-20-2009, 01:17 AM   #8
LPMarshall hack
Senior Member
I see. So am I correct in assuming that all modern amps have a cascading gain stage? Thanks for your help.
Old 12-20-2009, 01:23 AM   #9
Senior Member
Pretty much...except for the reissue stuff obviously.
__________________
Jon Wilder
Old 12-20-2009, 01:38 AM   #10
LPMarshall hack
Senior Member
You mean the reissue SLP's right? As always...awesome WILDER!!!
Old 12-20-2009, 01:42 AM   #11
Senior Member
Reissue SLP as well as the Bluesbreaker RI...basically any 4-input style Marshall.
And thanks for the kind words.
__________________
Jon Wilder
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
