MarshallForum.com
Reply
Thread Tools Display Modes
Old 12-16-2009, 02:51 PM   #1
axuality
Senior Member
axuality's Avatar
The back of my JCM800 has a "Slave out" - how do I use it?
It also has a knob to control the output. Is this meant to go to a recorder, or to the front of another guitar amp or power amp or what?
Thanks.
axuality is offline   Reply With Quote
Old 12-16-2009, 04:41 PM   #2
V-man
Senior Member
V-man's Avatar
Re: The back of my JCM800 has a "Slave out" - how do I use it?
Quote:
Thanks.
Be sure you have some good reputable info on this. I have heard that some amp>amp slaving can be hazardous.
V-man is offline   Reply With Quote
Old 12-16-2009, 05:51 PM   #3
American Viking
Senior Member
American Viking's Avatar
It's a direct out for the preamp section. Basically you can use it to push the front end of another amp, into a poweramp, PA, mixer, whatever you want. I have run the DI from a 2204 800 into the front end of a clean 2203 and the tone wasn't that great. Was not horrible either. Another way to use it is if an amp has a series effects loop you can plug the DI from the 800 into the effects return of the series loop and use only the power section of another amplifier.
There's a lot you can do with it but at the same time it can also be pretty useless. Recording with those amps sound better with a mic on the speakers and if you have another amp to drive with it in most cases they just sound better when you A/B them instead of slave one. Now I'm only speaking if you have no crazy effects on a huge pedal board. I suppose you could also have different effects running to the amp you're slaving and what not. I don't know.
I'm not sure if this helped or not, lol. Just experiment with it. Can't hurt anything, and of course, never run the amp without a load connected, but I'm sure you know that.
American Viking is offline   Reply With Quote
Old 12-17-2009, 11:41 AM   #4
axuality
Senior Member
axuality's Avatar
Thank you, man. You've really helped. This is really my first tube Marshall, and I'm almost aroused, I like it so much.
I started playing with a Sears tube amp, then '65 Super Reverb, then '65 Dual Showman,...didn't appreciate tubes because back then no one really did, because there WERE no SS amps I think. Now, I'm realizing just how good tubes were. ha ha slow learner.
I see you have a Marshall or two.
Old 12-17-2009, 11:42 AM   #5
axuality
Senior Member
axuality's Avatar
Quote:
Yea, I can imagine. Thank you.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
